mayoturbo
Turbo coupe
won the coupe on ebay. Plans are to put my metro turbo engine in until the bodywork is complete on my metro then will hopefully be fitting my spare 993cc turbo engine from a charade GTti. metro engine has a gt20 turbo, LSD, straight cut drops and gears etc Got most of the electrics working now. Need to modify engine cover, subframe and spaceframe for the metro engine to fit Want to have it ready to take on the drag strip in july/august
Sat Jun 02, 2012 7:54 pm |
Joined: Fri Sep 14, 2007 10:34 pm Posts: 1765 Location: In the workshop GTM: Cox/Coupe
Re: Turbo coupe
About 6 weeks to go to avon park! would be good to see you there
Sun Jun 03, 2012 10:57 am |
mayoturbo
Re: Turbo coupe
WEST wrote: About 6 weeks to go to avon park! would be good to see you there
Neil That is the date i am aiming for!
Sun Jun 03, 2012 11:28 am |
turbocox
Re: Turbo coupe
Oooo looking forward to this. What times you looking for
Sun Jun 03, 2012 2:40 pm |
mayoturbo
Re: Turbo coupe
would like to be faster than 14.8 because that is the quickest i have done in my charade gtti, although would really like to be in the high 13's
Tue Jun 05, 2012 5:05 pm |
Re: Turbo coupe
mayoturbo wrote: would like to be faster than 14.8 because that is the quickest i have done in my charade gtti, although would really like to be in the high 13's 150 Hp and a clean run should see you in that area with a bit of practice low 14s should be achievable certainly. We will find out in July Neil
Tue Jun 05, 2012 5:21 pm |
mayoturbo
Re: Turbo coupe
Car wont be ready for avon now so aiming to have it done for mini in the park instead. Few bits I still need to sort like the megajolt and starter motor/alternator wiring.
Mon Jul 02, 2012 1:55 pm |
mayoturbo
Re: Turbo coupe
Had it running tonight
Thu Jul 05, 2012 10:25 pm |
turbocox
Re: Turbo coupe
Thu Jul 05, 2012 10:50 pm |
mayoturbo
Re: Turbo coupe
Hope to see your car at avon this weekend. I shall be in my charade GTti
Fri Jul 06, 2012 1:37 pm |
turbocox
Re: Turbo coupe
Fri Jul 06, 2012 6:50 pm |
mayoturbo
Re: Turbo coupe
Well avon was wet yesterday.
Can't select reverse in the gtm. I think it may be where/how the reverse switch is fitted. It is on a metro linkage and the switch is mounted on the other side to original position in a hole which is factory made but it is not 180degrees round from original. The bottom plate has been swapped round so the gate is not the problem!
Sun Jul 08, 2012 8:25 am |
mayoturbo
Re: Turbo coupe
heres the gearbox before I bolted it back to the engine
Sun Jul 08, 2012 8:34 am |
minitici
Joined: Sat Jul 26, 2008 9:45 am Posts: 189 Location: Scotland [GTMOC 1190] GTM: Cox/Coupe
Re: Turbo coupe
mayoturbo wrote: Well avon was wet yesterday.
Can't select reverse in the gtm. I think it may be where/how the reverse switch is fitted. It is on a metro linkage and the switch is mounted on the other side to original position in a hole which is factory made but it is not 180degrees round from original. The bottom plate has been swapped round so the gate is not the problem! You did swap the gearstick locating pin and rotate the gearstick 180 degrees - didn't you?
_________________ 1967 Cox GTM; 1970 GTM Coupe, Lancia GTM Spaceframe , 1997 Rossa Mk2 (Two is never enough!)
Sun Jul 08, 2012 9:32 am |
mayoturbo
Re: Turbo coupe
minitici wrote: mayoturbo wrote: Well avon was wet yesterday.
Can't select reverse in the gtm. I think it may be where/how the reverse switch is fitted. It is on a metro linkage and the switch is mounted on the other side to original position in a hole which is factory made but it is not 180degrees round from original. The bottom plate has been swapped round so the gate is not the problem! You did swap the gearstick locating pin and rotate the gearstick 180 degrees - didn't you? Yes it was done before I had it. I checked it. Think the problem is I need to shorten part of the linkage, the gearstick does not rest in the center its too far back
Sun Jul 08, 2012 10:25 am |
