Rossa Type R build http://www.gtmdrivers.com/forum/rossa-type-r-build-t2725-30.html |
Page 3 of 4 |
Author: | scottmasterton [ Tue Jan 20, 2015 10:10 am ] |
Post subject: | Re: Rossa Type R build |
octance wrote: Looking forward to seeing some footage when you get a Go Pro. Car is fantastic Thanks we will hopefully have one for our next test |
Author: | scottmasterton [ Tue Jan 20, 2015 10:21 am ] |
Update We definitely need to fix this haha. Think we'll have to make some sort of alloy plate to stop it melting when it spits out flames. We got an Ikeya sequential shifter off a friend to see if we can modify it to fit the car, which would be brilliant Also just got an LSD from gripper diffs, a 6.33 final drive from M factory which should give us a top speed of around 130mph with 15s or around 145mph with 17s and a baffled sump kit from CPL Racing to keep the engine running smoothly. Hopefully test it all soon, the car should be even faster |
Author: | scottmasterton [ Sun Feb 08, 2015 12:09 am ] |
We've been doing a bit of work in the cockpit over the past couple of days Had the Engine and box out, took the box with final drive and LSD over to Sitech and fitted the baffled sump kit Also started on the final shape for the bulkhead next on the list is to fibreglass the bulkhead, sort out the brake setup a bit more, fit power steering and then probably put it back together for the next test |
Author: | West [ Sun Feb 08, 2015 11:37 am ] |
It will be interesting if you get the shifter to work. Has been one of my thoughts how to make a sequential style lever to H pattern. Neil |
Author: | scottmasterton [ Sun Feb 08, 2015 10:34 pm ] |
WEST wrote: It will be interesting if you get the shifter to work. Has been one of my thoughts how to make a sequential style lever to H pattern. Neil We should be able to get it to work providing prototyping goes well, at the moment it'll really just mean that we can't put it into the wrong gear and so we cant change down and blow it up haha |
Author: | scottmasterton [ Sun Aug 23, 2015 7:02 pm ] |
Thought I'd updated this thread ages ago We've managed to get some fibreglass work done on the bulkhead And try the K20 in an MGTF subframe for the rear Modifying it to fit the exhaust and for the engine to sit right Fabricating where the subframe connects to the rest of the cage Adding an analog rev counter to the dash display and power steering |
Author: | scottmasterton [ Wed Dec 30, 2015 1:34 pm ] |
Found some photos from earlier on in the build when we were designing the fuel tank and the shaping of the front of the tub to hold the front wheel |
Author: | scottmasterton [ Wed Dec 30, 2015 1:59 pm ] |
We've more recently been cutting out the old rear wheel arches and creating tubs for new ones as there was slight clearance issues and this may be a bit lighter also Made a front sump guard basic shape that we will remanufacture in aluminium Fitted these really light wheels only 4.7kg each corner with some D Mack tyres for testing |
Author: | Ken555 [ Wed Dec 30, 2015 6:16 pm ] |
I'm guessing DMT-RC as everything else comes in 18" only. |
Author: | scottmasterton [ Wed Dec 30, 2015 11:41 pm ] |
Ken555 wrote: I'm guessing DMT-RC as everything else comes in 18" only. Cant remember which ones they are but 15s and just for testing |
Author: | Ken555 [ Thu Dec 31, 2015 12:32 am ] |
They look like the old Maxsport RB5, I used to use on the Impreza. Road legal slicks, made for interesting driving on a wet A823 ! |
Author: | scottmasterton [ Sat Feb 06, 2016 7:35 pm ] |
Ken555 wrote: They look like the old Maxsport RB5, I used to use on the Impreza. Road legal slicks, made for interesting driving on a wet A823 ! Oh wait so they are haha |
Author: | scottmasterton [ Sat Feb 06, 2016 7:45 pm ] |
Just got the custom driveshafts from CPS drivelink really happy with how theyve turned out |
Author: | scottmasterton [ Sun Mar 27, 2016 2:56 am ] |
We've been welding and strengthening the MG subframe a bit more And working away developing the quick release throttle cables |
Author: | West [ Sun Mar 27, 2016 11:21 am ] |
Why the change to MGTF rear end? Neil |
Page 3 of 4 | All times are UTC [ DST ] |
