JTD108L - 1971 GTM Racer http://www.gtmdrivers.com/forum/jtd108l-1971-gtm-racer-t3325.html |
Author: | grizzler73 [ Mon Dec 07, 2015 11:45 pm ] |
Post subject: | JTD108L - 1971 GTM Racer |
Hello everyone Here are some pics of the tub and bits sitting in the container until I get my house/workshop sorted, as you can see it is very rusty! https://www.flickr.com/photos/109325599 ... 259679279/ and https://www.flickr.com/photos/109325599 ... 259679279/ |
Author: | turbocox [ Mon Dec 14, 2015 3:51 pm ] |
Post subject: | Re: JTD108L - 1971 GTM Racer |
I can't see anything on this link |
Author: | grizzler73 [ Tue Dec 15, 2015 11:54 am ] |
That's odd... here is a link to my GTM page on Flickr, anyone can access it. https://www.flickr.com/photos/109325599 ... 299050670/ |
Author: | West [ Tue Dec 15, 2015 10:06 pm ] |
Page link works ok Neil |
Author: | kano nordie [ Wed Dec 16, 2015 4:12 am ] |
Came up for me quicker than I could say Viagra John |
Author: | turbocox [ Sat Dec 19, 2015 7:59 pm ] |
grizzler73 wrote: That's odd... here is a link to my GTM page on Flickr, anyone can access it. https://www.flickr.com/photos/109325599 ... 299050670/ This one works^^^^^^^^ but the first one still doesn't work for me |
Author: | grizzler73 [ Thu May 05, 2016 10:42 pm ] | ||
Post subject: | Re: JTD108L - 1971 GTM Racer | ||
Here is my first stab at a better rear wishbone, using Minispares compettion inner bushes and 1/2" Rod ends. The little bosses line up with the 2 holes in the bottom of the mini hub carrier, these I will tap M8 and then drill the carrier for clearance. I was thinking I may do the steering arm locator as well just so it really is locked off!
Author: | minitici [ Fri May 06, 2016 11:16 am ] |
You might want to weld a vertical plate across the back of the bottom mounting plate for the upright. I did this to my standard GTM plates after they twisted. |
Author: | minitici [ Fri May 06, 2016 11:20 am ] | ||
Here is the bowed bottom bracket.
Author: | grizzler73 [ Fri May 06, 2016 1:03 pm ] |
good point, I will add it in. |
Author: | martin hassett [ Tue May 10, 2016 10:29 pm ] |
I felt that this was the weakest area of the Coupe suspension. Lifting off at 80 ( on private roads of course) the back end was noticeably moving around. Scarily, my Clio V6 has the same arrangement using the steering arm for toe-in control !! Martin |
Author: | kano nordie [ Wed May 11, 2016 7:15 am ] |
I don't think the A frame arms are the weak point, it's the bracket onto the hub that flexes, which is why people using a steering locking arm system get a better rear end controle. John |
Author: | turbocox [ Thu May 12, 2016 10:24 pm ] |
looking at your drawing, if you move the tie bar pick up from the underslung position, to the leading edge of the forward arm. You'll be able to loose some weight off the tie bar by shortening it every little helps for a racecar |
Author: | grizzler73 [ Sat May 14, 2016 11:05 pm ] |
I take your point Stuart, but to be honest I am skating on pretty thin ice regs wise with the rod ends so I can't see myself getting away with shortened tie bars as well, I will use the Group A type tie bars so I can adjust the toe in easily with that. I intend to build the rear end to be as easy to adjust as possible without it looking like a full on race car! |
