It is currently Sat Nov 21, 2026 11:19 pm
Oil leak from en O-ring/gasket
Post Oil leak from en O-ring/gasket
On my GTM K3, with K-series 1400 MPI engine, I have an oil leak from where a pipe comes out of rear of engine (ie facing rear of car). The pipe seems to be a push fit in (with rubber plug to secure it), and presumably has an O-ring that actually seals, and this I need to replace (haven't managed to get it out yet to inspect as access is difficult).
If you can offer any advice as to what O-ring I should purchase (assuming it is an o-ring), and ideas of where I might obtain it, I would be very grateful.
I have a photo of the location at: http://www.peterboroughareaweddings.co. ... /index.htm
Many thanks
Peter
Thu Oct 13, 2011 10:35 pm
Post Re: Oil leak from en O-ring/gasket
That looks (to Me) to be the speedo cable. I'm sure mine had an 'o' ring when I pulled it out, it put oil in a nice puddle :oops:
Thu Oct 13, 2011 11:16 pm
I think rimmer bros has a good online catalogue and this may actually list the size of the o ring :wink:
Fri Oct 14, 2011 10:42 am
Many thanks for your replies - I should have guessed it might be the speedo cable - here's hoping I can locate an o-ring.
Regards
Peter
Fri Oct 14, 2011 11:28 pm
