It is currently Wed Aug 12, 2026 8:05 am
K3 FRONT WINDSCREEN ! what is it from?
Post K3 FRONT WINDSCREEN ! what is it from?
HI , Does anyone know what the Donor Windscreen is for a K3 ? and if the rear is from a donor or a custom job ? Many thanks :D
Thu Mar 06, 2014 3:03 am
Post Re: K3 FRONT WINDSCREEN ! what is it from?
citroen visa ? citroen c15 ? I am not sure...
Thu Mar 06, 2014 4:43 pm
I am 99% sure that it was from a Citroen Visa or C15 van.
Matty
Thu Mar 06, 2014 4:44 pm
Hi , Great C15D Van , yes that looks like it, i'll get one glued in , Many Thanks :)
Thu Mar 06, 2014 7:48 pm
Can anyone confirm 100% that the K3 screen is Citroen C15? I'm going to need one eventually for mine.
Thu Aug 21, 2014 1:36 pm
Hi Rich, I have a Rossa 2 and that uses the screen from a visa (which is the same as a C15 screen). They are easy to get hold of either from ebay or new. I may have a build manual for the K3 on cd but not 100% if I still have it so will have a look for you at the weekend.
Thu Aug 21, 2014 5:42 pm
Thank you, much appreciated.
Thu Aug 21, 2014 6:14 pm
I had mine replaced last year on my K3, used a Citroen Visa windscreen however the glass did need to be cut down a little as it was a different size to the OEM pieces, was free of charge for me with the company which installed it. Hope this helps!
Fri Aug 22, 2014 11:30 pm
