Paul's k3 http://www.gtmdrivers.com/forum/paul-s-k3-t2686-255.html |
Page 18 of 23 |
Author: | catsam [ Fri May 18, 2018 3:54 pm ] |
Post subject: | Re: Paul's k3 |
I still need to make something to go over it |
Author: | catsam [ Thu Jun 14, 2018 6:35 pm ] |
Author: | West [ Sun Jun 17, 2018 11:02 am ] |
Looks like a cheeky arduino project. I still have not done mine yet. Custom board too very did you make the PCB yourself? Neil |
Author: | catsam [ Sun Jun 17, 2018 2:15 pm ] |
hi this is my attempt to make a speedo calibrator using a arudino I used http://fritzing.org/home/ to make the board it work very well. I have made boards by hand in the past but this did a much better job all I have to do is write a program for it |
Author: | West [ Sun Sep 16, 2018 10:32 am ] |
5v sounds perfectly reasonable to me for a speed pulse output. From memory the Honda setup is a trigger that is driven by a gear and worm gear off the diff, now the PG1 is basically a mirror image of the Honda box. Massive assumption here it may be around 4 pulses per revolution as on a Honda it is just over 4 pulse per rev. Neil |
Author: | catsam [ Wed Oct 17, 2018 6:32 pm ] |
thanks neil the speedo bored is now on hold for now I was going to do something about the black wheel arches but I have found that the wheels rubs on the roll bar when on full steering lock not good this is a link for a video this shows what happens when on full lock I hope this link works https://drive.google.com/file/d/1VOOLuw ... p=drivesdk |
Author: | catsam [ Fri Oct 19, 2018 7:54 am ] |
I think the essay way round this is to use a wheel spacer It needs to be 10mm |
Author: | jaybee [ Tue Oct 23, 2018 9:33 pm ] |
catsam wrote: hi all i thought this was going to be easy put some 10mm wheel spacers on i do not like this ide and i cant find any 10mm with longer studs i think i have two arb that look like the bottom ones in the photo thats why it hits so i was going to fit the one at came with my mgf sub frame it look like the one in the top of the ophoto nope i have the sering rack in the way its the one for the back came with the engine i could fit it so i facse forword and a cross the center of the sub fram like this photo but i have the radiator pipes in the way i will have to see if this will work if not its back to wheel spacers Paul, That Subframe was a bstrd to build but fun none-the-less and was the standard MGTF set up, but the MGF is essentially the same when it comes to the ARB. The heater pipes were potentially an issue, but I remembered parts I used in work a long time ago and had made spacers between the ARB and heater tubes using Stauff clamps (http://www.stauff.co.uk/products/pipe-clamps.aspx), which are used on industrial clean room installations. They worked a treat but they were in the boxes of bits when I sold the K3; otherwise, I would have sent them to you - I’m sure you can knock up something similar. J. |
Author: | catsam [ Tue Oct 23, 2018 10:18 pm ] |
thanks jaybee it looks like it will work I no what you used |
Author: | catsam [ Tue Oct 30, 2018 10:55 am ] |
I keep finding more work looking at the two radiator pips that run a long the bottom of the car. it looks like they have been hiting the road and are all dented. I will have to take them of and see how bad they are and see is i need some new ones |
Page 18 of 23 | All times are UTC [ DST ] |
