It is currently Fri Nov 20, 2026 10:27 pm
Re-gassing units and wiring problem.
Post Re-gassing units and wiring problem.
I have just had my Hydragas units on my K3 re-pressurised by Ian Kennedy. I drove the 200 miles down to Telford with minimal springing and home with springing which was/is the same as on a new Metro. The difference is remarkable and is money well spent.
On another note, I have found that the ignition feed from the fuse box to the starter has been replaced with a piece of household electrical earth wire. This by-passes the relay box and the immobiliser. Does anyone know what this immobiliser looks like and where to find it as I would like to reinstate the white and red wire, using the relay box as intended. Also can I just by-pass the immobiliser with an on/off switch?
Mon Sep 03, 2018 8:43 pm
Post Re: Re-gassing units and wiring problem.
i think there are two different alrm immobiliser one is 3as and was put on the older metros
and the over one is a 5AS and this is the same one used on the mgf
it should be in the dash in my car its just behind the stereo
Tue Sep 04, 2018 1:00 pm
