It is currently Thu Sep 09, 2010 3:27 pm
Honda powered Coupe!
Post Honda powered Coupe!
Not mine :lol:
but a fellow member on the crx-uk site, GTM Coupe Hilclimb car with D16 fitted, and been used in competition
http://board.hondacrx.co.uk/phpbb2/viewtopic.php?t=82714
Hopefully that link works without logging in if not ill copy and paste if needed
I am tempted, but really i dont need another, but im interested in the cage :roll: , must resist the temptation
WEST
IF wile e coyote had a GTM he would have one with Nitrous too! watch out road runner! The First GTM into the 11s, PB 11.00 @ 124.98 Mph on A048 tyres!
Tue Nov 04, 2008 8:01 pm
Post Re: Honda powered Coupe!
Link doesn't work Neil. :?
Tue Nov 04, 2008 8:29 pm
here we go then
frogracer wrote:
1989 GTM Coupe, built by us from new in 2004. This car has no V5 or identity, but has an MSA logbook for hillclimb and sprinting. Could easily make a circuit race car.
The car was hot dip galvanised from new, and is a coloured gelcoat finish as opposed to paint. It is in excellent condition, always garaged and used sparingly. (The pictures don't do it justice, it is a bit grubby and the weather was awful).
It has been converted to a stock D16A9, L3 tranny and stock ECU. It is complete, running and ready to compete. Also available is a chipped PP5 ECU, spare ex-CRX Challenge engine and box.
The GTM is rear engined and Mini-based, the Honda lump sits on a modified Mini subframe. The running gear is nearly all Mini, and the cage is an MSA approved unit built from T45 (lightweight) and certified by the manufacturer.
To answer some FAQ:
1. No - it will not be easy to SVA or get a V5, although it is certainly possible. The car has no headlights, handbrake, interior etc. A donor car could provide the identity.
2. I am 6'2" and over 15 stone and I can get in and out and compete in it.
3. It could be converted to B-series
4. It weighs 600kg odd
Before the cage was fitted
Mini power
Chassis and bodywork
Galvanised tub and chassis
Red gelcoat bodywork
Plastic sliding side windows, plastic rear window
Laminated screen
Rear arch extensions (removable)
Rear lights, brake lights, F&R indicators
Single central wiper
Performance Protection T45 6-point bolt in cage, MSA approved. Consists of rear hoop (triangulated into engine bay), diagonal, door bars, dash bar
Interior
Kirkey aluminium race seat
TRS 6-point harness (in date to 2011)
OMP 380mm suede wheel
Snap-off boss
10k RPM tacho with shift light
Mechanical temperature gauge
2.25l handheld fire extinguisher
Fuse box, cutoff switches
Engine and transmission
Stock Honda 1590cc DOHC D16A9 engine and 5-speed transmission
Maniflow stainless exhaust, repackable silencer
Front mount full width radiator and twin fans
Hybrid Honda/ Mini driveshafts
Wilwood hydraulic slave clutch cylinder
Suspension
Spax adjustable dampers (front)
AVO adjustable dampers (rear)
KAD Heavy Duty adjustable Radius Rods (Front)
Minispares Heavy Duty adjustable Radius Rods (Rear)
Adjustable negative camber Heavy Duty bottom arms (F&R)
Hi-Los (F&R)
Stock Mini cones
New wheel bearings and swivel pins all round
Brakes
8.4” solid discs front and rear
Mini calipers (rear) with stainless pistons
Alloy Girling calipers (front)
EBC Greenstuff all round
Goodridge brake hoses
KAD spilt Master Cylinders with bias bar
DOT5 silicone brake fluid
Wheels
4 x 6Jx13” alloys with Michelin slicks (worn)
Set 13” Minilite copies with road tyres (6J front, 7J rear)
Set scruffy 13” Minilite copies with Goodyear Eagle NCT tyres
Various
Alloy foam filled fuel tank with splash bowl and breather
Walbro High Pressure fuel pump
Andersen plug
Bunch more pictures here:
http://s46.photobucket.com/albums/f146/frogracer/GTM/
£3500 ono - not interested in P/X.
Jamie aka frogracer also knows of a second gtm that is registered,
Also advertised on 16vminiclub below, and you can pm him through there
http://www.16vminiclub.com/forums/viewtopic.php?t=14779
WEST
Tue Nov 04, 2008 9:37 pm
Nah u need to be registered for it to work...Looks a good car tho
Dont you Think Its Amazing that Buildings Cant Move But Can Sit Perfectly Still, Yet Humans Can Move And Cant Sit Perfectly Still??
Scottishmini.co.uk
Tue Nov 04, 2008 9:41 pm
Already sold :shock:
Come on then own up!
WHO BOUGHT IT?????????? :mrgreen: :mrgreen:
THE WORLD'S FASTEST 'A' SERIES COX GTM 1/4....13.502 @115mph MITP 08
Wed Nov 05, 2008 11:08 am
who got it?
Wed Nov 05, 2008 1:00 pm
Gone to a competition car dealer that seems to know a bit about GTMs and history is the word on the street
WEST
Wed Nov 05, 2008 8:30 pm
I bought this car about 4 weeks ago with the intention of sprinting and hill climbing it.
I bought from a dealer in Cheshire who was selling it on behalf of a pal of his, another dealer, who bought the car from Jamie's Dad.
I have joined the GTMOC and this forum and look forward to meeting some of you.
Regards
David Large
Mon Dec 21, 2009 9:55 pm
Good to see you found us David, I know Jamie and his Dad from another club, Im sure there will be a few questions with the car, seeing I too have been D16 powered in the past.
It will make an awesome hillclimb car, and a little development will make it even better im sure.
Mon Dec 21, 2009 10:20 pm
I have been a fan of the Cox GTM for a long time. I read the article on Cars and Car Conversions about 40 years ago and in the early 1970's I went to Manchester to look at the kit with a view to building one - I never did though. When I saw this one I just had to get it.
I also belong to another couple of clubs with my other kit car photo attached
David
Mon Dec 21, 2009 10:57 pm
