It is currently Tue Nov 24, 2026 11:08 pm
rad fan switch
Post rad fan switch
Where do you wire in a switch for the fans to cut in when it gets hot? There seems to be nothing in the raditor and I don't what it tobe a manual switch so i have to keep and eye on water temp the whole time. Thanks
Mon Jul 09, 2012 10:40 am
Post Re: rad fan switch
As there's no boss on the rad you could try something like this;
https://www.europaspares.com/product/23 ... 1416_.html
I used one on my K3 and it did the job - plus it's adjustable
Mon Jul 09, 2012 3:36 pm
yep, I have one of these ^^^^^^^^^^ as well on the MR2 Coupe.
Or you can try one of these............
http://www.minispares.com/product/Class ... .aspx|Back to shop
Tue Jul 10, 2012 9:14 pm
With a bit of installation work you could adopt a Peugeot 406 Thermo switch from GSF
These operate at 90-100 degree C and are normally position in the thermostat housing or near the top hose connector in the radiator.
With a relay addition they are capable of support high current cooling fans.
They are low cost about £12.00
REGARDS PiltV40
Tue Jul 10, 2012 11:22 pm
