catsam
Joined: Thu Jun 27, 2013 11:32 pm Posts: 492 Location: Norfolk GTM: Libra
car plugs
hi dose any one know where i can find a webpage that sells electric plugs. see pic the plug i need the plug that goes to the blue aluminum part in the radiator hose (top left of pic ) it should have a plug on the 2 wires (bottom middle of pic ) its the same as the plug that is in the pic thanks
Sun Mar 16, 2014 11:17 pm |
Dino
Re: car plugs
Mon Mar 17, 2014 12:17 am |
catsam
Re: car plugs
hi thanks that is just the part
Mon Mar 17, 2014 10:35 am |
madmazturbo
Re: car plugs
It looks like an injector plug. If you fail to get a connector I would just unscrew the plug as I have the same 25/32mm adapters for the water pipes my car and just threaded a 1/8npt temp sensor into it
_________________ Colin
Spin up the Rotrex
Mon Mar 17, 2014 5:19 pm |
catsam
Re: car plugs
can any help do you no where you can get the plugs for the GTM wiring loom adaptor. that plugs in to the standard wiring loom witch provides all the services to the engine. its like an extension led plug one end a socket on the other end im looking for the pug and socket part there are so many pugs and sockets which one is it
Tue Sep 15, 2015 8:39 pm |
Matty H
Re: car plugs
Here you go http://www.polevolt.co.uk/acatalog/Econ ... ctors.htmlThat plug is as used on the metro so if you can find a scrap metro and cut the plug off then just buy new terminals. Matty
Tue Sep 15, 2015 9:09 pm |
Rich
Joined: Mon Aug 18, 2014 6:07 pm Posts: 169 Location: Devon GTM: Libra
Re: car plugs
To search for them the two pin connector is a Junior Timer connection, the other looks like an Econoseal item.
Tue Sep 15, 2015 9:19 pm |
catsam
Re: car plugs
Hi thanks that is just the job
Tue Sep 15, 2015 10:20 pm |
