Rear LED Reverse/Fog lights
Continuing my LED obsession started here:
libra-led-front-indicator-marker-lights-t2755.htmlBought some Ring LED Fog and Reversing lights # RCT495 & 496.
I have a pair of the original incandescent units mounted inside the central bottom recess for reversing and a pair of fogs in the holes either side (rather than one of each in the middle). These are ok but not very weather proof and the contacts corrode (leading to intermittent failure) whereas the LED units are more sealed. The old units are 8cm high by 7cm wide, the LEDs are 8cm high by 10cm wide so will fit fine.
Got em today, the fogs are really bright & the reversing are less so but sufficient for their purpose. Will post before after pics when done.
Cost £47 posted off Ebay for the four.
SAS
