petesilcock
Joined: Wed Apr 15, 2015 4:52 pm Posts: 141 Location: Devon GTM: Libra
Sidelights
Hi all first post - just bought Libra from StewB
Does anybody know where you can get front sidelights/ indicators from New would be good as rusty
Pete
Wed Apr 15, 2015 5:06 pm |
Matty H
Re: Sidelights
If it is the early front end with the four seperate indicators and sidelights that areround and 74mm in diameter then they are from old land rovers and defenders, bolt on bits also do led units at £15 each if you wanted to go down this route. http://www.ebay.co.uk/itm/RDX-LED-Front ... 4859wt_721And welcome to gtm ownership. Matty
Wed Apr 15, 2015 7:46 pm |
petesilcock
Re: Sidelights
Matty
Thanks for information and the welcome to GTM ownership It is the ones around 70mm I will look on Landrover sites Beware - I will be asking more stupid questions
Pete
Wed Apr 15, 2015 8:39 pm |
petesilcock
Re: Sidelights
Sorry just saw and clicked the link
I don't expect LED with orange bulb is around for the indicators?
Wed Apr 15, 2015 8:41 pm |
sidewinder
Re: Sidelights
You can get clear orange or orange orange versions. Search WIPAC 73mm on ebay libra-led-front-indicator-marker-lights-t2755.htmlI used a variable flasher relay. SAS
Wed Apr 15, 2015 9:47 pm |
Tim Rowe (1130)
Re: Sidelights
Pete,
If you go for LED conversion the flasher module would need changing too. The flashing rate is determined by the current drawn by the lamps.
The indicators are also used on the later original minis, so they should be easy to get from somewhere like mini spares.
_________________ Tim Rowe
Wed Apr 15, 2015 9:50 pm |
petesilcock
Re: Sidelights
Thanks all
Really good to join a helpful group
My plans are to get the original car working well then fit the engine and box from Mondeo st220 I have the donor - low miles and drives well Next step for the transplant will be to offer up the engine / gearbox and make sure it will fit V6 - just for the noise??
Pete
Wed Apr 15, 2015 10:20 pm |
Malcolm_Ball
Re: Sidelights
Hi Pete, Not sure how big the ford V6 is compared to the KV6 But the K6 tub and boot are different on the V6 Libra. Cheers.
Thu Apr 16, 2015 1:41 am |
petesilcock
Re: Sidelights
I have the pictures of the change to the v6 tub. GRP is my thing so I will be able to alter the tub and retain the strength Duratec is narrower v angle so could need less inset
Pete
Thu Apr 16, 2015 8:20 am |
mitch2b
Joined: Thu Jul 26, 2012 1:45 pm Posts: 100 Location: chorley GTM: Libra
Re: Sidelights
i have the led lights from Boltonbits in Bradford, straight swap and damn sight better looking and brighter, yes you will need the rely too, but that just swops over too
Mitch
Thu Apr 16, 2015 9:23 am |
Matty H
Re: Sidelights
You can get the standard landrover lights if you do not want to go led they are super cheap but do not have any reflective housing behind the bulb, think this is why people have changed them to led to get a better light output. Matty
Thu Apr 16, 2015 7:41 pm |
petesilcock
Re: Sidelights
Thanks all Ordered LED front lights and relay from Bolt on Bits Much better than squiggling bulbs to get them to work for 10 minutes
Pete
Thu Apr 16, 2015 8:10 pm |
sidewinder
Re: Sidelights
LED units are more weatherproof than the normal bulb type too.
Fri Apr 17, 2015 12:11 pm |
