Hi Ian
Clamp On Exhaust Flexible Joint Repair Flexi Pipe tube Flex 38mm ID – 63mm ID [1.75 inch (45mm),8 inch (200mm)]
https://www.ebay.co.uk/itm/282902086936Should arrive tomorrow so can get it fitted at the weekend.
Only other job to do is improve the handbrake as it is not as efficient as it could be
45mm diameter is very tight....Changed to 50mm diameter and fits much better
