It is currently Fri Apr 26, 2024 3:39 am
Replacing clutch in a Spyder
Post Replacing clutch in a Spyder
The time has come to put a new clutch in the Spyder. Can this be done without dropping the engine?
Tue Feb 13, 2018 11:41 am
Post Re: Replacing clutch in a Spyder
I've not tried - have had plenty of opportunities whilst the engine was out :oops:
I would suggest it is possible to separate the gearbox without removing the engine but you won't be that far off. I'm assuming PG1?
Get the car fairly high up. You will need to pull the driveshafts (so drain the gearbox oil first), support the sump on a block of wood on a jack, take off the steady bar, Most likely take of the exhaust, or at least split it where the down pipe joins the rest, disconnect the gearbox mount, probably take off the clutch slave and speedo drive plus gear change cables (or rods).
I think the engine/box can then rotate around the RHS mount sufficiently to separate the 'box from the engine.
To be honest, by the time you've got that far you are only a few harness connectors and two RHS engine mount bolts away from removing the engine anyway. I lower the sump onto a dolly, remove the mount bolts and then lift the car high enough to roll the whole engine/box assembly out - much easier access for re-aligning the box input shaft back into the new clutch then - might be difficult to get them aligned if the engine is still hanging diagonally down...
Edit: Oh yes, and draining the coolant - I suppose that is a reason to leave the engine in! Undoing the main for/aft coolant pipe supports would give enough slack to rotate the engine down...
Good luck!
Tue Feb 13, 2018 6:43 pm
Easy enough to do leaving the engine in. Easier still with the Z cars suspension as removing the arm is really easy and gives loads of room. I had so much trouble with the gearbox I built I ended up being able to remove the gearbox in less than 30 mins.
Tue Feb 13, 2018 7:39 pm
cheers. Another job for when it gets warmer. Will try first with engine in
Tue Feb 13, 2018 7:58 pm
So was this do-able with the engine in? I’ve just trashed my clutch today....so need to replace. Presume Libra & Spyder are very similar to do!
Thu Sep 12, 2019 5:57 pm
Never did do the clutch..sold it to Westfield and bought a Libra instead
Thu Sep 12, 2019 9:12 pm
I replaced my gear box with engine in long time ago but seem to remember that I lowered the gearbox and bell housing side of engine down.
Mon Sep 16, 2019 9:51 pm
