It is currently Fri Jul 03, 2020 12:11 pm
Bottom Engine Steady bar bush?
Post Bottom Engine Steady bar bush?
Hi All
Any thoughts on where the lower engine steady bar bush came from?
Sun Oct 20, 2019 5:13 pm
Post Re: Bottom Engine Steady bar bush?
I think mine looked like the MGF's tie rod bush KKH100782.
You'd just have to push out the bush on yours and the above and swap em.
Mine started to allow too much movement (so I thought) and was replaced with home made PU top hat bushes (you actually can buy polybushes for this application). I cut all the rubber out but didn't bother removing the sleeve & retained the centre tube.
Mon Oct 21, 2019 3:23 pm
