It is currently Fri Apr 26, 2024 12:00 am
Hose GRH1104
Post Hose GRH1104
Is there a newer or alternative part number for the above hose? I can't seem to find it available anywhere in the UK.
Thanks.
Thu May 21, 2020 3:42 pm
Post Re: Hose GRH1104
You can still get them in the EU.
https://www.recambiosprom.com/tienda/Ma ... 2001394_gp
J.
Thu May 21, 2020 4:13 pm
Rimmer brothers suggests this as an alternative:
https://rimmerbros.com/Item--i-PCH10250EVA
Hope this helps.
Thu May 21, 2020 4:14 pm
What exactly do you want the hose for? It's mostly just cut up to provide 90° angles.
Thu May 21, 2020 10:39 pm
It's to replace the hose between the steel coolant pipe from the thermostat (that goes around the engine under the inlet manifold) to the alloy tube near the bulkhead that disappears off to the radiator. It's just a 45 degree bend section cut out of the hose and since both the GRH1104 and PCH10250EVA seem to be out of stock everywhere I've found this which should work in 32mm.
https://www.thehosemaster.co.uk/45-elbo ... ator-hose/
Have a look at Eliseparts. They have pretty much everything in silicon
https://www.eliseparts.com/shop/engine- ... one-hoses/
Fri May 22, 2020 11:14 am
When I had standard thermostat, I replaced that whole bit with a PEH100820 which eliminated a bunch of joins. It did need a reducer to fit on the underfloor ally pipe which is 28mm OD but hose is 32mm ID.
Fri May 22, 2020 12:41 pm
I like the sound of that, thanks.
Fri May 22, 2020 11:33 pm
