Late Libra Door Hinge Adjustment http://www.gtmdrivers.com/forum/late-libra-door-hinge-adjustment-t4540.html |
Author: | nikvanorton [ Tue Sep 01, 2020 11:18 pm ] |
Post subject: | Late Libra Door Hinge Adjustment |
Does anyone know how the top hinge can be adjusted on the very late Libra revised door hinges that go right through the door? It looks like there may be an eccentric bush in the door (could it be that easy?) but I'd like to check before I start turning anything. Cheers. |
Author: | Zagato [ Wed Sep 02, 2020 10:00 am ] | ||
Post subject: | Re: Late Libra Door Hinge Adjustment | ||
Not sure if this is late or early?
Author: | nikvanorton [ Wed Sep 02, 2020 10:10 am ] |
Thanks. That’s late, the one I have. The drawing makes the threaded nuts at the top and bottom look eccentric but I think I’m going to have to take it to bits to see. |
Author: | Zagato [ Wed Sep 02, 2020 11:19 am ] |
Probably just artists license Because the pins are relatively easy to move about l can't see them going to the trouble of eccentric bushes.... Keep us informed what you find |
Author: | sidewinder [ Wed Sep 02, 2020 3:09 pm ] |
If you do take it apart i'd like to see pics pics pics, i've never seen an upgrade kit for this. |
Author: | mark h [ Wed Sep 02, 2020 10:13 pm ] |
The bushes is made from 20mm hex bar with 16mm thread where is goes into the tube cannot remember what pitch but i have the tap at work because is i remade them in aluminium because the steel ones supplied were rather heavy the bush has a 10mm hole and is not eccentric i think you should be able to adjust where to bracket bolts to body if there is some clearance on holes i think the tube is used rather than nuts to keep the top and bottom parallel |
Author: | nikvanorton [ Wed Sep 02, 2020 11:52 pm ] |
Thanks. I did think that eccentric bushes may be a bit sophisticated! When the rain stops I’ll try adjusting the hinge plate on the car. |
Author: | sidewinder [ Thu Sep 03, 2020 10:44 am ] |
Do the pegs of 4 & 5 fit direct into 2 & 3, metal to metal as it were? |
Author: | nikvanorton [ Thu Sep 03, 2020 11:10 am ] |
sidewinder wrote: Do the pegs of 4 & 5 fit direct into 2 & 3, metal to metal as it were? Yes they do. |
