It is currently Sat Nov 28, 2026 1:37 pm
Alternator Upgrade?
Post Alternator Upgrade?
Hello
im looking to fit some ceramic interior heaters to the rossa ready for winter and its been suggested that fitting a higher output alternator would be a good idea does anyone know of a higher output alternator that could be fitted?
Mon Sep 06, 2010 12:10 pm
Post Re: Alternator Upgrade?
Depends on how easy a swap you want. It is possible to fit a non-Lucas alternator quite easily
I went for a 60A NipponDenso off a Proton Persona, just find something built in the Far East.
I think the Daewoo Matiz is a straight swap, but you need to take the engine out to access the alternator.
Then modified the mounts to fit, I went for a threaded rod, as the unit is quite a bit smaller. Then swapped the pulley over from the old one.
Mon Sep 06, 2010 4:08 pm
Same here, although I had a new pulley made. :D
Mon Sep 06, 2010 4:22 pm
very tidy :) 8)
Mon Sep 06, 2010 8:24 pm
Users browsing this forum: Google [Bot] and 1 guest
