It is currently Tue Jun 16, 2026 6:17 pm
[ 5 posts ] |
WEBER45
 rear subframe
I currently have a twin bolt subframe fitted in my rossa can i fit a single bolt subframe? i am talking about the tower mounts. i have a mk1 rossa does the mk2 have different mountings? any pictures would be helpful Thanks
| Sun Jun 19, 2011 9:28 pm |
Allen7
 Re: rear subframe
Sorry, can't say for sure but suspect not?
Build manual shows twin bolt fitting for the front subframe, rear is not shown, I suspect MkII is the same as the Mk I, no mention is made in the build manual's Mk II suplement (which is kinda sketchy).
Allen
| Wed Jun 22, 2011 11:18 pm |
PKR
 Re: rear subframe
As far as I am aware the central tub is the same on the Rossa I and II. They both use the twin bolt mini subframes by design.
| Fri Jun 24, 2011 11:29 pm |
Pantera2075
 Re: rear subframe
You can convert, but:
You need to bore out the central hole and reinforce it with a steel tube(If you can get at it)
You'll need a custom spacer for the top of the turrets
The main front lower mounts will need a spacer.
The back lower mounts maybe need altering if they support stuff.
| Sat Jun 25, 2011 1:01 am |
derekmasterton
 Re: rear subframe
I have a mk 2 rossa and both front and rear subframes have twin bolts ot the tower tops.
| Thu Jul 07, 2011 1:22 pm |
[ 5 posts ] |
