Door hinge. http://www.gtmdrivers.com/forum/door-hinge-t3193.html |
Author: | baxter [ Sat Aug 22, 2015 10:20 pm ] |
Post subject: | Door hinge. |
Has anyone been able to free a Rossa door hinge that is seized? One of my drivers door hinges is seized and I have had it soaking in wd40 over night with no luck and dismantling oil for a few hour, I have had it in a vice and can only move it back and forth a little bit. I havent tried heat yet because I have run out of gas in my blow lamp. There is no hinge pin to remove because it is welded at the top and bottom. |
Author: | Sven [ Sat Aug 22, 2015 11:19 pm ] |
Post subject: | Re: Door hinge. |
Although WD40 has many uses, its not the best product for freeing siezed bolts & brackets. Plus gas is a much better product for this type of problem. I've also heard that a 50/50 mix of automatic transmission fluid & acetone works really well. Probably a combination of a good soak & then some heat is your best option. |
Author: | RaymondH [ Sat Aug 22, 2015 11:20 pm ] |
I had the opposite problem in that mine were loose with a lot of play even though they had never been used. I got new ones from Alan at Rossabitz. |
Author: | baxter [ Sun Aug 23, 2015 7:52 am ] |
I will try the 50/50 mix today and try to heat the outside up, if all fails I will send Alan a message to see if he still has any hinges, infact you have just reminded me I need to ask Alan about some other items I could do with. |
