It is currently Wed Sep 23, 2026 9:07 am
Replacing Clutch Master Cylinder on Rossa Mk2
Post Replacing Clutch Master Cylinder on Rossa Mk2
I was out at Driftland (Lochgelly) last Monday and the clutch hydraulics packed up.
Luckily I did not have far to drive back home and only had to stop at a couple of traffic lights.
Bled the system when I got home and the pedal came back, however, there was a drip coming down the clutch pedal, so I ordered a new master cylinder.
The cylinder arrived yesterday and I got it fitted straight away.
What I did not notice was that the Rossa uses an extended push-rod on both master cylinders :?
Swapped the push-rod from the old one to the new one and everything was fine.
https://youtu.be/PGgAj-LdFow
Sun Jul 19, 2020 9:06 am
