It is currently Sat Oct 24, 2026 2:12 pm
Gtm libra rear suspension mounts mk1 or full suspension set
Post Gtm libra rear suspension mounts mk1 or full suspension set
Looking for at least two mk1 libra rear suspension mounts (the bits that bolt to the car with the ball joint through) or failing that a full rear suspension set up. Going to call westfield tomorrow but not holding much hope there.
Matty
Sun Oct 27, 2019 4:52 pm
Post Re: Gtm libra rear suspension mounts mk1 or full suspension set
Matty i have the suspension off my car at the minute if you cannot get a pair i can send you some dimensions
Ian
Sun Oct 27, 2019 7:50 pm
Hi,
Thanks for the offer but I do have the suspension mounts but they have corroded and cracked so need new or repair them.
Sun Oct 27, 2019 7:55 pm
Don't bank on Westfield holding parts. I enquired about some bits for my Libra and last response back at the beginning of August was:
Thank you for your patience. Unfortunately I do not have an update. Due to work commitments within the establishment. No fixed date has been arranged yet. I am asking and requesting a date so I can at least have items priced correctly, then I can advertised.
I am still waiting...………...
Mon Oct 28, 2019 9:10 am
Hi Matty,
I think I may be able to help you with those.
I’m on holiday until next Tuesday but I can have a look when I get back.
Drop me a PM.
Cheers, Jamie
Thu Oct 31, 2019 8:39 am
PM on it's way.
Matty
Thu Oct 31, 2019 7:13 pm
