Door window runner fitment http://www.gtmdrivers.com/forum/door-window-runner-fitment-t954.html |
Author: | Andy [ Thu Nov 26, 2009 7:45 pm ] |
Post subject: | Door window runner fitment |
Has anyone got tips on the best way to fit the window runner to the door, mine at present seems a bit bodged and I'm sure there must be a bitter fitment, any suggestions welcomed. Andrew |
Author: | Pantera2075 [ Thu Nov 26, 2009 8:12 pm ] |
Post subject: | Re: Door window runner fitment |
Which bit? Pics? |
Author: | Andy [ Thu Nov 26, 2009 9:06 pm ] |
Sorry not in the workshop, its the steel window runner that sits ontop of the fibreglass section of the door. The same one that the window locks into. |
Author: | Ken555 [ Thu Nov 26, 2009 9:12 pm ] |
Tigerseal and a few small countersunk rivets. |
Author: | Andy [ Thu Nov 26, 2009 9:47 pm ] |
Thats what I thought but I just wanted to make sure, can you still get the runner rubber/fabric insert strip (inside the metal runner) so not sure of correct name, silly question but "Tigerseal" is just a good quality silicone/adhesive? |
Author: | Ken555 [ Thu Nov 26, 2009 10:30 pm ] |
http://www.u-pol.com/countries/en/downloads/tds/tigerseal.pdf It's a polyurethane adhesive sealant, you can almost hold a car together with it. http://www.woolies-trim.co.uk/c-310-double-track.aspx Woolies stock the trim,but try Ebay as that's where I got mine |
Author: | West [ Fri Nov 27, 2009 4:15 pm ] |
With mine I used a coupe of M5 Countersunk stainless nuts and bolts and then a small bead of sealer i.e silicone. I wanted the option of removing the runner easily. To remove the windows all I do currently is slide tehm together, undo the bolts and they will push inwards to the car and get them out, leavignthe outer frames untouched West |
