It is currently Mon Aug 17, 2026 3:02 am
[ 7 posts ] |
Door window runner fitment
Andy
Has anyone got tips on the best way to fit the window runner to the door, mine at present seems a bit bodged and I'm sure there must be a bitter fitment, any suggestions welcomed.
Andrew
| Thu Nov 26, 2009 7:45 pm |
Pantera2075
 Re: Door window runner fitment
Which bit? Pics?
| Thu Nov 26, 2009 8:12 pm |
Andy
Sorry not in the workshop, its the steel window runner that sits ontop of the fibreglass section of the door. The same one that the window locks into.
| Thu Nov 26, 2009 9:06 pm |
Ken555
Joined: Fri Sep 28, 2007 7:39 pm Posts: 573 Location: Aberdeenshire GTM: Cox/Coupe
Tigerseal and a few small countersunk rivets.
_________________ Member No 1185
| Thu Nov 26, 2009 9:12 pm |
Andy
Thats what I thought but I just wanted to make sure, can you still get the runner rubber/fabric insert strip (inside the metal runner) so not sure of correct name, silly question but "Tigerseal" is just a good quality silicone/adhesive?
| Thu Nov 26, 2009 9:47 pm |
Ken555
http://www.u-pol.com/countries/en/downloads/tds/tigerseal.pdfIt's a polyurethane adhesive sealant, you can almost hold a car together with it. http://www.woolies-trim.co.uk/c-310-double-track.aspxWoolies stock the trim,but try Ebay as that's where I got mine
| Thu Nov 26, 2009 10:30 pm |
With mine I used a coupe of M5 Countersunk stainless nuts and bolts and then a small bead of sealer i.e silicone. I wanted the option of removing the runner easily. To remove the windows all I do currently is slide tehm together, undo the bolts and they will push inwards to the car and get them out, leavignthe outer frames untouched
| Fri Nov 27, 2009 4:15 pm |
[ 7 posts ] |
