It is currently Mon May 13, 2024 10:32 pm
[ 5 posts ] |
Pantera2075
Converting 12v/24v
I need help from any electrical gurus on here (That means you, Tim Rowe)
I've bought an electric water pump to replace the belt driven one on the 4age.
Problem is it's 24v
Rated current 3.5A
So, 84W
I know it'll run on 12v, but slowly. What can I do to speed it up?
Fri Mar 12, 2010 12:05 pm |
Tim Rowe (1130)
Re: Converting 12v/24v
I'll look into it. You'd need a dc/dc converter to supply the 24v, unless you want to run a second battery and have a split charge system running. Why can't you find a 12v one? I found one yesterday for a job at work for less than £100. Might end up being a cheaper option.
_________________ Tim Rowe
Fri Mar 12, 2010 12:22 pm |
Pantera2075
Cuz I enjoy the challenge If it comes to it, i'll re-wind the motor - will just have to find some sort of calculator/equation to work it out.
Fri Mar 12, 2010 1:25 pm |
Tim Rowe (1130)
Surely you'd just need double the amount of windings, for the motor to run at the same speed with half the voltage. Can the motor take that much extra copper in it's case size? I'm still firmly in the camp that you'd be better getting a 12v pump, as it cuts down on connections and components and therefore reduces the chance of failures, which on the water pump I would take as essential. http://www.mawsolutions.com/html/electric_water_pumps.html
Fri Mar 12, 2010 1:46 pm |
Pantera2075
Hmm, Lessening the amount of windings gives more speed/less torque, but the wire needs to be thicker.
So, to bring the torque back up, I need the same amount of windings in thicker wire - I think you're right Tim.
I'll be doing some trials over the weekend anyway - the pump as it is will do 50liters/min on 24v, and I only need 20-25, so it might work sufficiently as it is.
Fri Mar 12, 2010 2:16 pm |
[ 5 posts ] |
