It is currently Fri Apr 23, 2021 9:12 am
Handbrake
Post Handbrake
Need to adjust handbrake which end needs jacking up is there one adjuster or each cable separately
Ian
Fri Mar 26, 2021 8:30 pm
Post Re: Handbrake
Assuming a pretty standard Rover/MGF caliper is in use, the handbrake is adjusted inside the cabin under the fibre glass cover.
You can just see the adjuster nut behind the handbrake lever in the attached image <NOTE: Not my picture, one from an Internet Build site - can't remember whos now.>
Phil.
Fri Mar 26, 2021 9:22 pm
Post Re: Handbrake
Thanks Phil saves me getting my beer gut under the car
Ian
Sat Mar 27, 2021 9:06 am
Post Re: Handbrake
Thanks for that Phil 5 min job got the exhaust flexi sorted and an headlight change not a bad afternoons work
Ian
Sat Mar 27, 2021 8:19 pm
Post Re: Handbrake
No worries Ian.
I stripped tattered fabric from the two A-pillar trims and started on the passenger side door card.
Suffice to say I'm not enjoying trying to get old fabric glue off the fibreglass panels - not sure what's the most effective, white spirit, paint thinners, scraping with a Stanley knife blade or sanding with sandpaper.
New tyres on Monday !!
Phil.
Sat Mar 27, 2021 10:01 pm
Users browsing this forum: PhilBSpyder and 1 guest
