nikvanorton
 Hose GRH1104
Is there a newer or alternative part number for the above hose? I can't seem to find it available anywhere in the UK. Thanks.
Thu May 21, 2020 3:42 pm |
jaybee
Joined: Sun Oct 15, 2017 7:44 am Posts: 138 Location: Glasgow GTM: Rossa
 Re: Hose GRH1104
Thu May 21, 2020 4:13 pm |
Tim Rowe (1130)
Joined: Fri Sep 28, 2007 7:56 pm Posts: 739 Location: In the garage,Sileby, LEICS GTM: Libra
 Re: Hose GRH1104
Rimmer brothers suggests this as an alternative: https://rimmerbros.com/Item--i-PCH10250EVAHope this helps.
_________________ Tim Rowe
Thu May 21, 2020 4:14 pm |
sidewinder
 Re: Hose GRH1104
What exactly do you want the hose for? It's mostly just cut up to provide 90° angles.
Thu May 21, 2020 10:39 pm |
nikvanorton
 Re: Hose GRH1104
It's to replace the hose between the steel coolant pipe from the thermostat (that goes around the engine under the inlet manifold) to the alloy tube near the bulkhead that disappears off to the radiator. It's just a 45 degree bend section cut out of the hose and since both the GRH1104 and PCH10250EVA seem to be out of stock everywhere I've found this which should work in 32mm. https://www.thehosemaster.co.uk/45-elbo ... ator-hose/
roger
 Re: Hose GRH1104
Have a look at Eliseparts. They have pretty much everything in silicon https://www.eliseparts.com/shop/engine- ... one-hoses/
Fri May 22, 2020 11:14 am |
sidewinder
 Re: Hose GRH1104
When I had standard thermostat, I replaced that whole bit with a PEH100820 which eliminated a bunch of joins. It did need a reducer to fit on the underfloor ally pipe which is 28mm OD but hose is 32mm ID.
Fri May 22, 2020 12:41 pm |
nikvanorton
 Re: Hose GRH1104
sidewinder wrote: When I had standard thermostat, I replaced that whole bit with a PEH100820 which eliminated a bunch of joins. It did need a reducer to fit on the underfloor ally pipe which is 28mm OD but hose is 32mm ID. I like the sound of that, thanks.
Fri May 22, 2020 11:33 pm |
