It is currently Thu Oct 21, 2021 10:12 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Libra speedo
Post Re: Libra speedo
Well excellent service from AK speedo's for the new lcd display ordered wednesday evening from website arrived 9.30am friday morning fitted in easily and the re assembly was simple. Powered the unit up on the bench for the stepper motor to reset to its home position then pressed on the pointer at 0 mph fitted glass and bezel back on then fed square wave from signal generator into input to test operation all was well fit back in car tomorrow
Ian
Fri Feb 07, 2020 8:09 pm
hi ian
i m trying to attempt to make a speedo calibrator using a arudino for my k3
i think i have a 5v square wave signal coming from the standard rover box
it sounds like from your post you might no this
have i got his right
thanks
paul
Wed Feb 26, 2020 9:45 am
Paul I fed in square wave from signal generator and gradually turned up the amplitude from zero so I did not measure the amplitude but if it is fed from proximity switch on the car guess this is 12V. It looks like the gen was set to 6.5V pk-pk so this is +/- the speedo 0V so looks like the threshold is around 6.5Vdc you can try 5V but may be slightly low
Ian
Wed Feb 26, 2020 5:13 pm
Hi i know this post is old but i have just got a libra and the Libra speedo screen is not working
Does anyone have a gtm Libra speedo for sale the VDO/EBC one
Thanks Paul
Sun Sep 26, 2021 4:11 pm
Thanks Paul
If it is just the lcd not working they are fairly easy to replace.
Sun Sep 26, 2021 4:46 pm
Available on EBay
https://www.ebay.co.uk/itm/124526024445 ... Sw4zdf~xMY
Mon Sep 27, 2021 9:54 am
http://www.akspeedo.com/vdo-lcd-repair.php
I think these are the parts you need...
Mon Sep 27, 2021 1:28 pm
Thanks that looks like it thanks
Mon Sep 27, 2021 1:41 pm
