It is currently Thu Oct 21, 2021 10:32 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
Libra speedo
Post Libra speedo
Does anyone have a gtm Libra speedo for sale the VDO/EBC one
Ian
Tue Jan 28, 2020 6:50 pm
Post Re: Libra speedo
Do not have one but why do you need one ?
Tue Jan 28, 2020 7:52 pm
Westfield have a speedo from the blue write off for sale https://parts.westfield-sportscars.co.u ... ct_id=1181
Tue Jan 28, 2020 8:26 pm
Matty I have one but the LCD has crapped out they don't like the cold I am going to take it out and see if I can get the pt no off the display and replace it just thought i would ask on the off chance. Phil thanks i had seen that but it is in poor condition looks like it came out of a crashed car so lcd may be no good on that thanks for the replies
Ian
Tue Jan 28, 2020 9:22 pm
I'm pretty sure I have one
I will look and come back
Pete
Wed Jan 29, 2020 8:21 pm
Pete thanks
Ian
Thu Jan 30, 2020 9:42 am
I have the full set going once I fit my new dials. I’m probably a year away though
Colin
Spin up the Rotrex
BMW 435d M Sport x drive
BMW 320d M Sport
Thu Jan 30, 2020 11:03 pm
This firm sell the parts you need all will repair it for you.
http://www.akspeedo.com/vdo-lcd-repair.php
This is the discussion on westie forum.
https://forum.wscc.co.uk/forum/topic/13 ... nt-1444398
Sun Feb 02, 2020 2:25 pm
Thanks guys that is really helpful
Ian
Sun Feb 02, 2020 6:38 pm
Got the speedo out today and took it apart waiting for new LCD will do a write up once I have it back together
Ian
Wed Feb 05, 2020 6:42 pm
Please do Ian. I have this issue with mine (temperamental LCD, more blank than on) and have a spare but couldn’t see how to get it apart?
Any advice on how to get it apart would be welcome.
Wed Feb 05, 2020 11:10 pm
The bezel is crimped on to the front I got behind it with a small flat blade screwdriver and carefully levered it out slightly from the back working around the circumference once there is a small gap insert the blade under the bezel with the screwdriver at approx 15 degrees to the horizontal and work around the whole bezel very slowly easing the screwdriver handle slightly towards the rear of the speedo with each 360 deg rotation of the tacho this gradually opens up the bezel until you can remove it. Takes a few minutes but comes off without damage. Once the glass etc is out there is a thick black spacer ring which did not want to come out i slipped a small flat blade screwdriver between this and the white case and there is a groove in the black ring used this to lever a mm or so out in multiple places around the circumference. Next problem you cannot spin the needle around as per the video as the plastic trip spindle is in the way so go to the stepper motor spindle and carefully lever off with screwdriver final point is where the ribbon cable fits into the connector lever top of connector up carefully it only comes up 2mm and is retained in the connector but frees the cable
Ian
Thu Feb 06, 2020 11:46 am
One further point do not pull on circular black centre on pointer needle it will snap off it is a separate part
Ian
Thu Feb 06, 2020 11:54 am
Brilliant Ian, thank you.
Thu Feb 06, 2020 9:30 pm
I will take some pictures it will explain it better but not sure how we post up now
Ian
Fri Feb 07, 2020 9:35 am
