Re: Libra Steering Geometry
Spider wrote:
Are the nuts attached to a spreader plate behind the fibreglass or do you need to access the nuts? (looks impossible)
Hi Spider, Unfortunately the nuts aren't captive, just standard nylocs. Access is a pain (quite literally). There are access holes in the bulkhead/kick plate box section. Have to remove the carpet and there should be some bits of hardboard or similar glued over the holes so remove those too. You can then get an arm holding your 10mm spanner through the access hatch by lying in the footwell. Particularly hard on the driver side as you have the pedals and steering column in the way too. Your are likely to get a bit of glass rash where your wrist/forearm rubs on the opening edges too! Have some spare M6 nylocs as if you drop one you may not be able to reach to retrieve it and it'll annoy you forever rattling around in the box section!
