It is currently Sun Apr 18, 2021 9:15 pm
My poor Rossa is Exhausted!
Post My poor Rossa is Exhausted!
The exhaust on my Rossa - Mk2 - is to put it mildly at its end of life. It has been greatly modified (insert cut into small pieces and then welded back together so it comes out below the bodywork and the iopposite side from normal :? :?
The manifold to the first joint seems ok :?: but who knows till it all comes off
Any ideas on what can be used to make up the exhaust???
Cheers Phil
Mon Mar 15, 2021 4:06 pm
Post Re: My poor Rossa is Exhausted!
Phil.
Hambly's sell one for the Coupe that may be a good starting point, or maybe Rossabitz.
https://hamblysportscars.co.uk/shop
J
Fri Mar 19, 2021 5:34 pm
Cheers - spoken to both of them
Rossabitz don't stock them now - but I have the details
Similar with Derek - I have the details
This is the starting point with cut/bent tail pipe on the wrong side covered with heat wrap :shock:
Incorrect sizing of pipes so they couldn't seal properly
and some very interesting welding on the 2intto1 pipe :shock: :shock: :shock:
Fri Mar 19, 2021 7:33 pm
