It is currently Thu Oct 21, 2021 9:14 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4
Spring rate/ length
Post Re: Spring rate/ length
Thank Sanzo,
Yep, I'm getting mine from Mike S, LHD and good price for a new unit.
Tue Oct 12, 2021 8:49 pm
I posted some pics a long time ago - there is a section on the input shaft that is flat on the metro one but splined on the TF one. It is where the pinch bolt goes through. A couple of splines need grinding flat over a 6mm section or so IIRC otherwise when you try to get the pinch bolt through you'll find you can't and as that'll be with your arm through the access hole down by the pedals you'll curse. Compare the two before you install the new one and you'll see.
Tue Oct 12, 2021 9:53 pm
sanzomat wrote:
Tyre pressures I've found work best:
Road (205/45/15 all round) 18psi front 22 rear
Track semi's (195/50/16 front, 225/45/16 rear) 16psi front 20 rear
Track slicks (200/580/16 front, 210/610/16 rear) 16psi front 18 rear.
These are all cold pressures. When it gets really hot I let a bit out but I find if I start lower it feels a bit unsure for the first couple of sessions in the morning. When I re-check them (if I remember to) after they've cooled back down they end up as 15 front and 16 rear. When fully hot they increase by about 6psi on the rears i.e. 22 hot
Did the "track" pressures produce the best times? They are surprisingly low.
Thu Oct 14, 2021 2:38 am
Yep, those are what I found gave the best times (trial and error) although on UK track days you aren't allowed to time your laps so obviously only discovered later when analysing the video. No phone apps where ever used :wink:
Thu Oct 14, 2021 7:53 am
So I will be tracking (1 lap autocross) with semi-slicks 205/45/16 all round. From your numbers (16-F 20-R) I am thinking to start at 16-F 22-R
Thu Oct 14, 2021 11:17 pm
If you only have one lap you may need to start a bit higher. I usually take the first lap a bit steady to warm the tyres (which increases the pressure a bit). If you don't have a warm up lap the cold pressures would need to be higher as they'll still be cold for most of that lap. I'd go 18F 22R in that situation
Fri Oct 15, 2021 9:47 am
