It is currently Sat Mar 06, 2021 11:40 pm
Window rubbers
Post Window rubbers
Good evening all
What do the window rubbers come from please.
The originals seemed to be glued into place.
I must admit very well too - still stuck after 20 years
so what glue would that be
2nd is very simple - just me being wimp
The I think Metro wing mirrors - screwdriver and lever off the back to change the glass?
Pete
Wed Nov 11, 2020 8:29 pm
Post Re: Window rubbers
This is the adhesive - expensive but it works:
https://www.ebay.co.uk/itm/3M-Adhesive- ... SwEOhfjbp0
Thu Nov 12, 2020 12:15 am
petesilcock wrote:
Good evening all
Pete
You can by the weatherstrip from Woolies by the metre. Sikaflex or similar adhesive should be fine.
GTM Libra 2.5 V6
Thu Nov 12, 2020 10:18 am
Do you mean the windscreen Pete? If so it's bonded in and mine has a lower case 'h' profile trim pushed on to it.
The door seals are Rover Metro.
Mirrors you just prise off at the obvious seam.
Sat Nov 14, 2020 12:54 pm
Thankyou all for help and replies.
In no particular order
Side window rubbers are available from Car Builder and another rubber trim supplier.
Thank very much about the adhesive - Once stuck in and the door put back together I really do not want to have rubber not stuck well.
Mirrors - Very difficult to pop off the back without damaging the plastic - underside and carefully !!
Pete
Fri Nov 20, 2020 3:06 pm
For unclipping the mirror surround I used an old credit card - slip in a corner of the card and then slide it around the mirror. Much less likely to mark the plastic mirror frame than a screwdriver or suchlike and it worked a treat for me.
Fri Nov 20, 2020 3:27 pm
