It is currently Wed Oct 28, 2026 11:21 pm
adjustable bias pedal box from KAD
Post adjustable bias pedal box from KAD
hi,
I completing parts for my coupe
and I have a question....
if it will fit under the hood? I converted coupe from RHD to LHD and I need dual-circuit brake system ( it was single-circuit with mk3 servo )
http://www.kentautodevelopments.com/sho ... -cylinders
Fri Nov 01, 2013 1:34 pm
Post Re: adjustable bias pedal box from KAD
Hi Flapjck.
I made a dual circuit with a bias bar for a mini using a standard mini pedal box modified using cylinders and bias bought from Trident engineering at Silverstone, these parts will be used in the GTM now being shipped to me, I also have to convert the chassis to LHD as I noticed there are no holes for the steering rack and master cylinders when I crated all the bits
Fri Nov 01, 2013 2:29 pm
any pics?
Fri Nov 01, 2013 5:21 pm
Only if you're patent :) I have not started stripping the twinny mini for its bits and will prep and paint chassis, make the roll cage and attach the body before that :roll:
Fri Nov 01, 2013 7:53 pm
This is the pedal box I fitted,
http://www.compbrake.com/pedal-boxes/un ... -3036.html
They use to do one specifically for the mini but seems they just do a universal one now, the kit was very good, all I had to do was lift the bulkhead at the pedal box location by 50mm and you got a proper 6:1 ratio pedal and individual cylinders. it worked a treat in my setup and that coupled with the 4 wheel discs had by far the best brakes I had ever encountered on a mini even from my racing days.
My build log on the "projects" section should show you how it fitted
Fri Nov 01, 2013 9:44 pm
