It is currently Sun Nov 22, 2026 12:06 am
Andy Spaldings GTM coupe for sale
Post Andy Spaldings GTM coupe for sale
1983 GTM Coupe,
This Coupe was restored by Andy Spalding in 2010.
Fitted with a 1430cc MED A-Series Engine, strait cut close ratio gears, cross pin diff, coil-overs, adjustable suspension and roll bar It has the works.
See andys-83-coupe-t577.html
The car has just been rolling road tuned at Rawles in Alton (the Healey 3000 specialists).
It produced 90 Hp at the wheels and Rawles estimate this at 120+HP at the flywheel.
Unfortunately after the dyno test, the car now produces a lot of white smoke from the exhaust and will need to be trailered.
It has a MOT until July 2015
The spec below is from Andy’s sales thread and the engine is believed to be unchanged since
andy-s-gtm-coupe-t1690.html?hilit=andy
Professional paint job 4 years ago
New radiator (VW golf)
New wiring throughout
New interior
Cobra bucket seats with 4 point Sabelt Harnesses
Only one Cobra seat is fitted, the second one is supplied with the car.
Engine Specs as below
Block MED 501MR
1275 A+ late model block
73.5mm bore
Oil/water galleries oversized
Steel centre strap
ARP Bolts
Crank MED 840
1275 Cooper S
84mm stroke
Nitrided, bladed, wedged, cross drilled
Balanced
County 010 mains
Conrods
1275 Cooper S 521
Shot penned, lightened
Balanced
County big ends
ARP Bolts
Pistons
Omega 73.5mm 11cc dish
Omega rings
Balanced
Timing
KCMD286SB camshaft (spider drive) 106°
ACL cam bearings
Kent vernier timing gears
Flywheel/Clutch
Lynn Rogers Billet Steel Flywheel 3.1kg
Lynn Rogers Billet Steel Backing plate
Grey diaphragm
Alcon sintered paddle clutch plate
Gearbox
1300GT Rod box
Minispares SCCR kit
Minispares SC Drop Gears 1:1
Minispares Cross pin diff
Centre oil pickup
Hardy Spicer Output Shafts
Head
12G940
Offset valves
37mm Rimflow Inlet
31.5mm Rimflow Exhaust
Minispares 240lb progressive doubles
Minispares 1.5 ratio rockers
45 DCOE on 6” ali manifold
Custom LCB large bore exhaust
Suspension
Fully adjustable rose jointed arms front/rear
Rose jointed rear locking arms
Coilovers
Brakes
1275 GT AP setup front (grooved)
VW Golf GTI rear
Bias control pedal box
Braided lines
The car now has a removable steering wheel.
The car has Cobra bucket seats, but only one is fitted. The other one is supplied with the car.
The car is road registered and has a MOT till July 2015.
The car is located in Sandhurst Berkshire
For Sale at £ 3550 ono
Contact Martin on 07957867131
Fri May 22, 2015 6:15 pm
Post Re: Andy Spaldings GTM coupe for sale
Hi,
Any idea whats happened with the engine?
& also has the clutch been returned to a standard set-up?
Fri May 22, 2015 8:57 pm
Hi.
I don't know what the issue is with the engine. I'm not an engine guy.
I do not know if the clutch has been changed from the spec I posted. I suspect not.
The clutch was no problem for road use...which is all the use I ever gave it.
Martin
Sat May 23, 2015 8:42 am
Hi All
Just seen my old GTM is for sale! By the photos, she still looks in superb condition (pleased to see that she's been looked after)! No seriously, I always said that she is probably the best coupe in the country, the rebuild being absolutely stunning and was sad to have to sell the car. The amount of money and time that has been spent on this car to get it to such a high spec - Hats off to Andy - some lucky person's in for a treat!! Long live my old coupe !! Hope it goes to someone on the Forum well have to wait and see.
Thu May 28, 2015 9:45 am
Post Re: Andy Spaldings GTM coupe for sale -price drop
Now £3150
Martin
Sat May 30, 2015 9:13 am
Sold
Fri Jun 05, 2015 3:12 pm
