It is currently Mon Nov 23, 2026 6:09 pm
Central locking
Post Central locking
I have a faulty central locking solenoid it a master unit drivers door but is only 4 wires not the usual 5 anyone any ideas or have spare unit.
Matty
Thu Jul 28, 2016 7:06 pm
Post Re: Central locking
Get rid if it's the rover items, I used after market sovs from Maplins much more power and nicely constructed they are a 5 wire unit also.
Jamie
V6 GTM Libra '10 years in the making!!!'
Libra V6
Hawk AC Ace
TVR 3000M
MG ZTT 180
Skoda Fabia VRS
TVR Griffith 400 (coming soon)
Sat Jul 30, 2016 10:08 am
That is the problem mine is only 4 wire not 5.
Can fit as five if I know how to wire it.
Matty
Tue Aug 02, 2016 8:26 pm
Can you work out what the 4 wires on your system are?
I'm guessing that there are two for the coil and the other two would be a switch for feedback. You may be able to use a 5 wire solenoid into your set up.
Wed Aug 03, 2016 6:53 am
I think there is a orange wire and a pink wire from the metro loom one is 12v live when the button is pressed to open on your fob via the 5AS and one is 12v live when pressed to lock. There is 4 solonoids in the Maplins kit two of which have two wires but they can all be adapted to what you have, all you need is a 12v tester, its not as hard as you think.
Jamie
Libra V6
Hawk AC Ace
TVR 3000M
MG ZTT 180
Skoda Fabia VRS
Sat Aug 06, 2016 7:44 pm
After a bit of investigation I have found that I have a solenoid with two wires that is triggered by the alarm keyfob and the four wire master unit is then triggered to open the other solenoids so in theory can I just connect the drivers and passangers solenois to the keyfob feed.
Just do not know how this supply get there ie relay, fuse etc and do not want to overload it.
Matty
Sun Sep 04, 2016 11:32 pm
Sorted this out by removing the faulty master 4 wire unit and replacing it with two change over relays.
Matty
Sun Oct 16, 2016 8:08 pm
Glad you got it sorted :)
Sun Oct 16, 2016 8:25 pm
