It is currently Fri Nov 27, 2026 9:14 am
Coupe wall thickness
Post Coupe wall thickness
Does anyone know what wall thickness is used for the box section rear spaceframe in a coupe? There is a bit I want to redesign so need to order some new steel. Thanks
Sun Jun 01, 2014 7:29 am
Post Re: Coupe wall thickness
It will be 16swg or 18swg.
That's about 1.5 mm to 1.2 mm.
It's what you will normally get supplied with if you order 25 mm x 25 mm square section tubing.
Sun Jun 01, 2014 9:54 am
The rear box section is normally 18swg 1.2mm wall thickness.
When I have removed or replaced any of the tubes I have used 16swg 1.6mm wall. :D
Sun Jun 01, 2014 10:09 am
Thanks :D
Sun Jun 01, 2014 9:42 pm
yep 18swg is the norm
Sun Jun 01, 2014 10:35 pm
