It is currently Tue Nov 10, 2026 9:20 pm
Coupe windscreen rubber
Post Coupe windscreen rubber
I'm going to be calling into Europa spares in a couple of hours to pick up a windscreen rubber for the coupe. Anyone any idea what length I need? Also, is there an optimum for the glass thickness/body thickness dims?
ta
Wed Mar 12, 2008 10:49 am
Post Re: Coupe windscreen rubber
Evenin all
Does anyone have any suggestions on the above? I am just about to replace the windscreen and before I go for the standard mini-type rubber (3mm body/3mm screen), does anyone know anything different?
The rubber I am planning to use is part number R398-C from Woolies (http://www.woolies-trim.co.uk).
Your thoughts would be appreciated!
Barny
Thu May 29, 2008 6:11 pm
From memory my Coupe screen was 5 - 6mm thick.
The thickness of the body is variable. I would measure it in a few places and choose the appropriate rubber.
On my car the screen aperture was way oversized so I used the Mini rubber with the extra flange built in. It only comes as complete loops so I bought 2, cut them and superglued them back together.
Thu May 29, 2008 6:23 pm
OK, I have measured the coupe screen and it is 6mm. As I don't currently have the car with me, can anyone advise on body thickness?
Sat May 31, 2008 11:08 am
As John says they do vary, just measured mine and I've got about 4mm along the bottom, 2.5mm at the top and no more than 2mm max on the screen pillars.
Sat May 31, 2008 4:42 pm
BF wrote:
... before I go for the standard mini-type rubber (3mm body/3mm screen), ...
Barny
Are you sure about that? 3mm seems very thin for a screen.
Sat May 31, 2008 4:46 pm
Cheers Dino, it'll be the 6mm screen / 3mm body variant then.
Mon Jun 02, 2008 10:05 am
Windscreen rubber info for future reference:
Body - 2.6mm to 3.2mm
Screen - 6mm
Part no. R399-C (black rubber insert) or R399-358 (chrome effect insert) from
http://www.woolies-trim.co.uk.
New screen has been fitted over the weekend to confirm all this!
Tue Jun 10, 2008 3:52 pm
