It is currently Mon Nov 09, 2026 7:35 pm
Door Latch Mechanism
Post Door Latch Mechanism
Does anyone know what the door latch mechanism is out of on a coupe, mine has given up the go and won't work, are they the same as a late model mini/allegro? Info would be appreciated.
Mon Jun 02, 2008 9:00 pm
Post Re: Door Latch Mechanism
Allegro.
Mon Jun 02, 2008 9:02 pm
Thanks, know of where I can get 2 of them from as both mine are shagged
Mon Jun 02, 2008 9:05 pm
Also used on Lotus/Astons etc, use to be listed in the europa catalogue with that listed fitment next to it, dunno if its still in there, about £25 each
Mon Jun 02, 2008 9:10 pm
Also Marina and Range Rover :D :D :D
Mon Jun 02, 2008 11:55 pm
Are you talking about the actual mechanism in the door with those two? I know they use the same handle as the GTM but from memory of my old Rangey the mechanism is quite different - maybe they were different between 3/5 door models or changed over the years though.
Wed Jun 04, 2008 6:57 pm
you can take them to pieces and reassemble them with care - the casings seem to be bent fairly easily and respond well to straightening and reworking ..
Wed Jun 04, 2008 7:16 pm
Thanks Peterb, they have already been pulled apart once before and now the springs are now collapsed. I have found replacements now so all it good. Mine were Allegro
Wed Jun 04, 2008 9:05 pm
Sound !!!
Wed Jun 04, 2008 10:04 pm
