It is currently Thu Oct 22, 2026 1:51 am
electric waterpump
Post electric waterpump
Does anyone use a davies craig EWP with controller on their coupe? I like the idea of being able to circulate the water still once engines turned off. Also a bit less power losses and slight increase in economy is always a good thing!
Sun Nov 30, 2014 3:14 pm
Post Re: electric waterpump
I started using a Mikuni electric pump on the Kawasaki engine in my race car with good results, but not tried a Davies Craig on an A series, if I did I would remove and blank off the the standard pump. From an engineering point of view a variable speed engine driven pump in series with an electric pump is a big no no :cry:
Sun Nov 30, 2014 4:27 pm
Not using It with an a series. Will be removing the pump if I get one
Sun Nov 30, 2014 7:18 pm
I used one on mine.
I didn't use the controller but I did use a thermostatic switch so that it would not run until after the thermostat had opened.
I also kept the original water pump.
I wired it direct to a 12v supply so that after the engine was turned off it would continue to run to get rid of the heat soak problem.
Mon Dec 01, 2014 10:36 am
Just a word of caution when wiring electric pumps, don't be tempted to wire a switch into the pump circuit, if the ignition is on the pump should be running, it is too easy to forget to switch on the pump in the heat of the moment :oops:
If you want to keep the pump running with the engine not running switch off the ignition and fuel pump then switch the ignition back on to keep the water circulation going :wink:
Tue Dec 02, 2014 4:32 am
Or, alternatively you could use a delay off relay, which would let it run for a set time after the ignition is turned off. :wink:
Fri Dec 05, 2014 1:35 pm
Good alternative :wink:
Fri Dec 05, 2014 2:10 pm
ordered an alloy waterpump and controller. It's the size of the turbo :lol: going to mount it up front somewhere hopefully
Tue Dec 23, 2014 7:38 pm
Or, alternatively you could use a delay off relay, which would let it run for a set time after the ignition is turned off. :wink:[/quote]
That is what is fitted to my Radical by the factory.
David
Land Rover Freelander 2
BRA 289 Cobra replica
Porsche 968 Coupe
Radical PR6
Fri Dec 26, 2014 10:09 am
I managed to fit mine just below the standard water pump. It was a bit of a squeeze but it worked fine and kept the plumbing simple.
Sun Dec 28, 2014 6:46 pm
