It is currently Fri Nov 27, 2026 11:18 pm
Fuel for thought.
Post Fuel for thought.
Hi everyone, as slowly rebuilding my frankinstein coupe and am replacing fuel lines and upgrading to facet fuel pump. Does anyone know the best location for this little device? According to the manufacturers it needs to be lower than the tank, which in the coupe is a touch difficult.
Sat Sep 08, 2018 7:35 pm
Post Re: Fuel for thought.
I have my fuel pump mounted above the cooling pipes on the slope of the front bulkhead.
Just about level with the bottom of the tank.
Sat Sep 08, 2018 9:06 pm
Thanks, it sure is a tight spot to get at. Was thinking the other end of tunnel, though this might be too far away from pump. I ve also tried to keep all small pipes outside tunnel and just have cooling inside tunnel. This also has completed matters as fuel line goes from outside car to inside then into engine bay. I do like to make life difficult.
Sat Sep 08, 2018 9:55 pm
I've just mounted my facet pump on bobbins above the entrance of the tunnel. Don't know how I'll get to it if it fails out on the road, but it's the only place to
fix it.
Thu Sep 13, 2018 7:43 pm
