GTM Coupe Tyre Size and Ride Height
01hpo
Joined: Wed Apr 20, 2011 11:57 pm Posts: 7 Location: Paraguay GTM: Cox/Coupe
Hi All,
My GTM Coupe is a late model with the body designed to take 13" rims. Currently I'm running 165/60 r12s. Which to me look a little small in the wheel arches compared to other coupes on the web. The most popular tyre size in the 13" rims are 175/50 r13 which more or less have the same rolling circumference as what i already have.
The gap between the top of the tyre and the bottom of the wheel arch is about 2 1/4" all round. Having used the coupe for a few years it is far too low and i'm forever bottoming out especially around the lanes where i live. The ride height measured to the bottom of the sills is 4" at the front and 4 1/2" at the back. Reading on here this is at least an 1" less than its supposed to be however if i raise the car by an 1" the wheels in the arches are going to look even worse. (I've attached a picture of the coupe)
I need to settle on wheel and tyre choice as the gearbox is due a rebuild and i'd like to get the final drive ratio correct for the wheels.
So my questions is what size rims (width and diameter) and tyres are people using and what gap does that leave you with between the tyre and wheel arch?
| Tue Nov 08, 2016 1:19 pm |
01hpo
 Re: GTM Coupe Tyre Size and Ride Height
Just realised the pic didn't attach so here it is. Attachment:
I also just found the tyre sizes that West is somewhere else on the forum :- front 175/60r13 increased radius of .75" from my 165/60 r12 rear 185/60r13 increased radius of .9" So thanks West gives me some food for thought.
| Tue Nov 08, 2016 3:47 pm |
Welcome to the forum good to see you used the search function I use to run 165/60/12 a long time ago. Also 165/65/13 is not a bad option if you feel you do not need the extra width and come in quite a few tyre options. Neil
| Tue Nov 08, 2016 10:58 pm |
Starmag
Joined: Fri Aug 15, 2014 4:49 pm Posts: 141 GTM: Cox/Coupe
Another yellow one!
| Tue Nov 08, 2016 11:21 pm |
01hpo
I'm glad someone likes the colour!
To be honest at the moment I'm quite happy with the level of grip i've got on the 12s. It's only ever going to be a road car and I'd like to think that with some other rims they'd be a little lighter than a 13" setup. Having done some more looking I think it may just be the illusion of the gap between the actual rim and arch (as opposed to the tyre and arch) being less on a 13" that makes the arch look fuller.
I'd still be interested to know the ride height (floor to sill) and tyre to arch gap on some other forum members cars.
I'm far more of a function than form (asthetics) sort of person so worrying about this sounds a little stupid but the wheels will affect a lot of other things through the planned rebuild, final drive ratio only being one. I want to buy some different rims at some point anyway and would like to make an informed decision.
| Wed Nov 09, 2016 1:04 am |
grizzler73
Standard ride height was 5" front 5.5" rear I believe, for a road car I would not venture much lower than that, especially as the gear change drops lower than the sump. I think 165 x 13 60 profile will look better, plus a generally more common tyre to get, lots of choice!
| Wed Nov 09, 2016 1:34 pm |
Yoda74
Welcome 01hpo
These are the figures I got from John not so long ago when I was trying to find a good setup. (Still am)
Ride height front 5” – rear 6” Camber front & rear 1.5 degree Castor angle Front 3-5 degree Castor angle rear 0 degree Toe in front 3 mm (1/8”) Rear toe in 2-3 mm Tyre pressure front 18 – 20 psi rear 22 – 24psi
About wheel and tiresize, I currently am trying to get flat spots out of my tires, if that won't work I too have got to make decissions about tire- and maybe wheelsize. I think it's an important decission for the loods and handling of the car. Interesting topic
Harold
| Wed Nov 09, 2016 7:11 pm |
01hpo
Thankyou for the responses. I'm currently building myself a set of digital corner weight scales (still waiting for some bits from China). I would like to see what the crossweights are doing for my own interests before I start changing anything.
She's currently on the original machined rubber cones and shortened trumpets so assume it's a bit low as the cones are tired.
I can see some hilos being on order soon.
| Wed Nov 09, 2016 7:44 pm |
Midas
Joined: Tue Nov 13, 2007 4:36 pm Posts: 47 Location: Peak District
grizzler73 wrote: Standard ride height was 5" front 5.5" rear I believe, for a road car I would not venture much lower than that, especially as the gear change drops lower than the sump. I think 165 x 13 60 profile will look better, plus a generally more common tyre to get, lots of choice! not many of those about these days. https://www.tyreleader.co.uk/car-tyres-165-60-13/
| Tue Nov 15, 2016 8:56 pm |
grizzler73
Sorry should have qualified that, I mean there is a lot of choice at 13 inch.
| Tue Nov 15, 2016 10:17 pm |
Midas
grizzler73 wrote: Sorry should have qualified that, I mean there is a lot of choice at 13 inch. That's true, I guess the time will come for those to be thin on the ground with the way wheel sizes are increasing on new cars. Lots of 65 series tyres currently https://www.tyreleader.co.uk/car-tyres-165-65-13-77/I guess the original big wheel coupe size of 155/70x12 would be another option, but the performance of tyres that size is probably no match for the 165/60x12 https://www.tyreleader.co.uk/car-tyres- ... erby=prixD
| Tue Nov 15, 2016 11:20 pm |
