GTM Libra
Post GTM Libra
Need some of the metal fastners that hold bonnet and rear clam shell down. Bronze look thick washer with flush fitting bolt with allan key top. Any idea where to get them please?
Also metal radiator pipe, drivers side, from top of radiator. Probably a metro part that is cut to fit.
With thanks.
Wed Apr 13, 2016 4:14 pm
Post Re: GTM Libra
Can't help with the originals, but these are very nicely made and about the same size.
http://www.tegiwaimports.com/select-car ... -32mm.html
Wed Apr 13, 2016 4:29 pm
Post Re: GTM Libra
I got a load of replacements from demon tweaks.
Wed Apr 13, 2016 5:55 pm
Post Re: GTM Libra
I got my screws from ebay. Just search for 'M6 countersunk stainless allen'. I bought some 16mm & some 20mm ones.
Can't help with the washers as i re-used the ones i had.
Wed Apr 13, 2016 6:59 pm
Post Re: GTM Libra
My original washers were ally and fixings M6 csk stainless. Look on ebay for "countersunk washer aluminium" or "countersunk washer stainless" the 'turned' ones are similar to stock.
Radiator pipe is #6 cut down http://www.rimmerbros.co.uk/Item--i-GRID000433 as per the original instructions.
Though, the side branch (that goes to the back of the car to the header tank) could do with being positioned higher on the tube to aid prevention of air in the top of the rad.
Someone on here did just such a mod: radiator-change-t3207-15.html?hilit=radiator pic of it on this thread somewhere.
SAS
Wed Apr 13, 2016 8:17 pm
Post Re: GTM Libra
Thank you all for help.
Wed Apr 13, 2016 8:32 pm
Post Re: GTM Libra
I got mine from pro bolt in stainless
https://www.pro-bolt.com/stainless/stai ... rsunk.html
Colin
Spin up the Rotrex
BMW 440d M Sport x drive
BMW 320d M Sport
Wed Apr 13, 2016 8:56 pm
Post Re: GTM Libra
I ended up using plain flat washers and dome headed bolts could not be bothered faffing with countersunk bolts and washers (hard luck Ian :oops: )
Wed Apr 13, 2016 10:09 pm
