It is currently Sun Nov 22, 2026 5:25 pm
GTM ROSSA SOFT TOP FITTING
Post GTM ROSSA SOFT TOP FITTING
I've managed to buy an unfitted soft top for my gtm rossa mk1 and have i think all the parts to fit but no instructions. Does anyone have the fitting instructions or even just some pictures of one fitted would give me a rough idea. Any help would be great.
Nick
Fri May 16, 2008 12:02 pm
Post Re: GTM ROSSA SOFT TOP FITTING
Is the Mk1 similar to the Kseries? if so then the rear lower portion of the hood is held on by use of four thumb screws, two in the top of the rear panel and one on either side inside of the cabin, the front is obviously held in place by the two catches and then there is two side rails (one either side obviously) that have a hole drilled in that hooks into a peg at the front and there is also a cross brace that slots into a hole in each of the side rails (about half way along their length). Hope this helps, otherwise I can take some photo's and email them to you of the set up folded down and up etc. (only just worked it out myself so is still fresh in the mind, as to what you do first etc. I am still experimenting but it is easier if you have four hands).
Fri May 16, 2008 4:51 pm
Good work Nick, if you don't mind my asking where did you find the soft top? I've been after one for ages and never managed to find one, and I don't have the 'forward vision' of the Ian Johnson's to construct my own... :)
Tristan
Sat May 17, 2008 10:45 am
Got it off ebay £165 i think but its new. any detailed pictures would be great my email is weber45dcoe@msn.com.
The frame work all fits into place like a glove just need some pics or instructions to get it looking right.
Nick
Sat May 17, 2008 4:12 pm
Hi Webber,
Where did you get the soft top from please? I am looking for one for my K3.
Mon Aug 11, 2008 8:44 pm
oops sorry, just read the previous post!!!
Mon Aug 11, 2008 8:45 pm
