It is currently Fri Nov 27, 2026 5:37 pm
HELP water leak
Post HELP water leak
Just bought a rossa mk2, 1275 a plus engine and i have a split hose. The hose goes from the water pump to the sandwich plate on the head to a pipe coming out of the engine/cabin bulkhead(to radiator) and finally i believe to the expansion tank. Has anyone any idea what car this hose comes from and where can i get one? Having a fair bit of experience with carb minis tells me its not from one of them. I think it might be from an a plus powered metro as they had the front mounted rad, expansion tank, water pump in same place, and i believe the sandwich plate under the thermostat housing. Any help much appreciated as i can't drive the car with it losing this much water :( I wish i had a build manual or a list of donor parts :(
Mon Oct 05, 2009 8:23 pm
Post Re: HELP water leak
If it's the hose I'm thinking of it will be horse shoe shaped with a long and a short stub coming off it. It is off a 1275 Metro but I'm not sure what year. However, if the one on mine is the original one for the engine (if you see what I mean) then it's 1990. I found one on ebay a while back and I've just had a quick look but there's none there at the moment :(
Mon Oct 05, 2009 8:48 pm
Hi mini_mad
Welcome to Rossa ownership.
I have copies of GTM Rossa Build Manuals in stock
along with many other spares.
Please contact me as below if you need anything.
Alan Britton.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Tue Oct 06, 2009 9:46 am
Sounds like the bog standard "bottom" hose from any A-series Metro - '81 thru '90
Tue Oct 06, 2009 4:36 pm
Thanks for confirming my thoughts guys, will be straight down the local motor factors, so that I can get back out it in. Just the oil leak to sort out now :roll:
Tue Oct 06, 2009 6:25 pm
