It is currently Tue Nov 24, 2026 11:37 am
how hard a job?
Post how hard a job?
how hard of a job is it to fit a rover k series ? can i modify the subframe like in a mini conversion and do you think i will need to make any body modifications? thanks for any advice
Wed Jul 20, 2011 6:05 pm
Post Re: how hard a job?
I'm sure if You wade thru' the old posts You'll find a fair bit of info :)
But the 2 lumps that go either side of the engine (ebay 2nd pic) make it difficult, unless You start chopping bits off the back of the car and making a spaceframe to tack on the back in place of them.
Wed Jul 20, 2011 6:28 pm
i have an idea of how to do it but i was hoping someone had attempted it before me im tempted to thin out the two lumps modify the original subframe to fit the k series then brace it with the roll cage but i think i may need to try and get some more pictures first and work out how im going to run my brakes as i was running the breaks from the throtlebodies
Wed Jul 20, 2011 7:15 pm
I'm assuming you are talking about running the servo, with a car that light and the right 4 pot calipers you should'nt need a servo at all.
Wed Jul 20, 2011 9:32 pm
This is a common question.
Peter & Paddy attempted it years ago and after much hard work
and a complete redesign produced the K3.
Save yourself a lot of work and buy a K3.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Wed Jul 20, 2011 11:04 pm
see pic
File comment: it can be done in hinde sight though id have bought an elise or VX and put a big engine in it
Thu Jul 21, 2011 8:01 pm
see pic
Thu Jul 21, 2011 8:04 pm
Now thats how you do it.
Thu Jul 21, 2011 10:53 pm
Arrr.......... Prop Errr job 8)
Does the hard top still fit :?:
Fri Jul 22, 2011 12:14 pm
yes the hard top still fits designed around it but does require the front of the roof and screen surround to be notched out around the cage and the fixings have to be moved.
Sat Aug 13, 2011 6:36 pm
wow
Thu Mar 07, 2013 9:09 pm
