It is currently Tue Nov 24, 2026 5:09 am
New member: old questions
Malcolm_Ball
 Re: New member: old questions
aChildSeatInThat? wrote: So the answer is that a Coupe can indeed get through IVA. Good work - I'm sure lots of people would have bet against it
| Fri Jan 20, 2012 5:34 pm |
aidover
Hi Mike,
I got my Coupe through what was at the time (2000) the initial introduction of the SVA / for cars purchased before a certain date it wasn't the full test (e.g. the car wasn't subject to the 'minimum radius / sharpe edges' requirement).
From what I can remember the biggest problem was the location of the front indicators / miniumum height above the road requirement (as the logical place for them, under the front bumper, was too low - I ended up half sinking them into the bonnet, Lotus Elise style). Also there was some debate about showing a white light to the front with the bonnet up (just scraped though on this). I had already opted for dual circuit brakes so no problem there, but did fail on the Mountney steering wheel (as it had holes in the spokes / so got replaced). The Chassis Number as supplied by GTM was 1 digit too short (so I added a digit with a matching stamp). As you've already identified, E numbers on the glass (windscreen and door glass) and mirrors. The speedo had to be appropriately calibrated within a presribed tolerance (I was in the process of getting a mechanical speedo done but it took so long that I ended up with an electronic one / got the mechanical one back after the test).
I guess there are a myriad of other things introduced since 2000. Good luck if you decide to go for it.
_________________ Andrew
| Fri Jan 20, 2012 5:52 pm |
David Large
Joined: Sat Dec 19, 2009 8:48 am Posts: 304 Location: Walsall, West Midlands GTM: Cox/Coupe
I think it would have to be road legal for that class and it seems unlikely that the car can become that. David minitici wrote: Hi Mike, I would think that your Coupe could run any engine and be eligible for "Modified Limited Production Cars" for hillclimbs and sprints. - assuming that you do not modify the chassis between the wheel centres, change the relative positions of the engine & transmission or change the suspension type.
_________________ Land Rover Freelander 2 GTM Coupe/Kawasaki track car - with Turbo attached and repaired/rebuilt engine BRA 289 Cobra replica Porsche 968 Coupe Radical PR6
| Fri Jan 20, 2012 6:24 pm |
minitici
The MSA category "Modified Specialist Production Cars" would be OK for a non-road registered Coupe.
The "Specialist" category also permits engine swaps (unlike Modified Series Production Cars).
| Fri Jan 20, 2012 9:01 pm |
Users browsing this forum: No registered users and 3 guests |
