speedtorque
 New Rossa MkII
Hello, I purchased a Rossa MkII last week from a chap in the North East. It's been a fun week of ironing out little problems and getting the thing running, but it's not a bad little driver now, the brakes could be better though. I'm afraid I will be pestering you lot for advice on most things as I have very little information on the car and am learning as I go. The only blessing is my previous fun cars have been all A Series engines (Morris Ital, Marina, MG Midget, Austin A35) so I'm ok with the engine stuff. I'm looking forward to developing this car and enjoying it for years to come. John M Attachment:
| Sun Nov 01, 2015 9:03 pm |
Sven
 Re: New Rossa MkII
Hi John & welcome Looks a nice Rossa you have there.
| Sun Nov 01, 2015 11:27 pm |
Jaykart1227
 Re: New Rossa MkII
Hi and Welcome. Nice looking car that Enjoy the forum - plenty of knowledgeable chaps on here (not including me).
| Mon Nov 02, 2015 8:06 pm |
RaymondH
 Re: New Rossa MkII
Hi John. Good to see another Rossa and a nice looking one it is too
| Mon Nov 02, 2015 8:37 pm |
speedtorque
 Re: New Rossa MkII
Thanks guys.
Do any of you know where I can get a build manual or anything to help me get my head around how the car is built and with what parts? I have the text and a few pics of the brochure from a website. Also, is there anyone who sells specific parts for Rossas?
| Mon Nov 02, 2015 10:52 pm |
RaymondH
 Re: New Rossa MkII
You need Alan Britton at Rossabitz on 01733844839 who also has build manuals. If you do a search on here for Rossabitz you should also find his address. Alan is usually around here somewhere but he's been very quiet for a while. I think the he also trades as Specialist Engineering.
| Mon Nov 02, 2015 11:28 pm |
baxter
 Re: New Rossa MkII
Hi John nice car you have there, if you pm me your email address I will send you a copy of the build manual. Regards Rich.
| Tue Nov 03, 2015 10:05 pm |
dastardlyman
 Re: New Rossa MkII
your car looks wonderful. wish mine looked that good.
| Tue Nov 10, 2015 8:45 pm |
speedtorque
 Re: New Rossa MkII
Thanks guys, it doesn't look so nice since I've pulled the soggy carpets out and investigated the wiring! I think proper looms have been used, but the there is some ad hoc wires floating about that I need to find out what they do. Whoever did this only had red wire as ALL of it is in red, even the earths. The reason I am investigating it is the battery light flickers when it's running, the voltage is 14.3v at the battery and 12.6v with the engine off, so I think the alternator is probably OK, but the wires to the dash look like they could be the culprits...
I'll keep going.
| Fri Nov 13, 2015 7:14 pm |
RaymondH
 Re: New Rossa MkII
Good luck with that  I absolutely HATE those damned Scotchloks  My ignition light used to flicker too but it was fine after I fitted a new alternator and now it just needs a minute or two before it goes out  Many moons ago I had a car whose ignition light was on permanently and that was apparently due to a faulty diode but it still charged the battery.
| Fri Nov 13, 2015 9:09 pm |
speedtorque
 Re: New Rossa MkII
I fixed it!
Here's how: Spend hours investigating every scotch block, chock block and dodgy splice. Remove if not essential and make a proper join if needed. This process familiarised me with the loom enough to spot something that looked like a voltage stabiliser joined inline to the wiring, the metro gti clocks already had one, so I removed the additional stabiliser and bingo, sorted.
In the process I decided the dashboard has suffered some really bad workmanship and nothing is held in well enough to survive track days or regularity events. I'm split on whether to remove it and mount a motorcycle type clock set to the frame work (ugly I know) or try and rebuild the dashboard with fiberglass mat, then mount some better clocks and switches properly? It will be ok for now, but some people should be banned from building kit cars, this thing has been butchered!
| Fri Nov 27, 2015 9:21 pm |
