It is currently Fri May 01, 2026 1:31 pm
[ 6 posts ] |
How small does a Coupe sunroof need to be?
Tim Rowe (1130)
I'm toying with the idea of a sunroof, so I can get a bit more air flow through the car on the sunny days. What are the maximum dimensions that the sunroof can be? I've spotted one that is 750 x 460 overall dimensions. Would this fit, I've had a measure and seems to be within a fairly flat piece of the roof, but I'm not sure.
_________________ Tim Rowe
| Fri Mar 14, 2008 3:20 pm |
Pantera2075
 Re: How small does a Coupe sunroof need to be?
How about a full Targa????
Otherwise, Pontiac Fiero sunroofs are huge - or try looking at one of the electric ones from a Honda Prelude or newer del sol CRX - that retract outwards?
Play it right and you could get one with a lift out panel, then fix a "bag" to the underside of the bonnet for storage.
Either way, you will be affecting your rollover protection - what little there is.
| Fri Mar 14, 2008 3:37 pm |
Tim Rowe (1130)
| Fri Mar 14, 2008 3:47 pm |
Andy
I used a Mitsibishi Lancer 89 - 92 one it is almost identical to the original one just slightly squarer through the corners. Very easy fit. I can give you the dimensions if you need them as it is only sitting in place and not fully screwed up.
| Fri Mar 14, 2008 11:09 pm |
Tim Rowe (1130)
Dimensions would be good. Cheers
| Sat Mar 15, 2008 9:01 am |
rooster
Joined: Mon Nov 05, 2007 7:23 pm Posts: 46 Location: north east, durham
the one that is in my coupe will be coming out in the near future, as im going to fibreglass it up as they look better with no sunroof!
| Sat Mar 15, 2008 5:31 pm |
[ 6 posts ] |
