Fast Eddie
 Steering play
Hello everyone. I have been trying to sort out my tracking/steering of late. Things are greatly improved since I changed to adjustable components on the front end with new bushes. I haven't got round to fitting the new bushes on the rear yet. Anyway I still have some vagueness to the steering around the straight ahead position and about half an inch of play on the wheel. I am starting to suspect this is partly to blame. Is it common to have some play in the steering, and if so can it make the car wander about when travelling in a straight line? I haven't had a very close look at the steering rack/column components yet but thought I'd post up the question to see what folks think and advise.
Ed
| Sat May 14, 2011 11:24 am |
CamelotR
 Re: Steering play
No, yes. One of the strongest points of the mini is the precision of the steering. As the mechanism is a rack and pinion-type, it is not very usual to wear out, and nearly never developes measureable free play. Half an inch at the wheel is a HUGE play. Usualy anything above 1-2mms noticeably effects the straight-line stability on a mini. Soo You got to find out the problem as this can be dangerous. Points to look at: - track rod ends - inner ball joint getting loose - wheel bearings - loose fitted streeting rack - loose fitted subframe (if rack is mounted on the bulkhead) - worn felt bush in the rack (play is mainly on the offside in this case) - loose fitted steering rod/steering wheel Theese are the main points. If everithing proves to be OK, then You should remove the rack and show it to a specialist - or replace it with a good one.
| Sat May 14, 2011 11:55 am |
 Re: Steering play
Fast Eddie wrote: ... I haven't got round to fitting the new bushes on the rear yet. Im sure you will notice a good change by doing the rear too, I can remeber when i chnaged a few rear components when i first got mine all those years ago, it made a huge differeance replacing all the bushes and resetting the tracking. Neil
| Sun May 15, 2011 6:56 pm |
turbocox
 Re: Steering play
what tyre pressures have you got in the front tyres
| Sun May 15, 2011 8:56 pm |
Fast Eddie
 Re: Steering play
I have 18psi on the front and 24 on the rears...
| Mon May 16, 2011 1:28 pm |
SportsLibre
Joined: Sat Nov 22, 2008 10:24 pm Posts: 77 Location: englandshire GTM: Cox/Coupe
 Re: Steering play
Get rid of all the rubber from the rear, under power the standard rubber tends to introduce rear "steering" movement.
_________________ Gtm Coupe, Jeffery J5, Mini Italian Job, Radical Clubsport and a road (tow) car
| Tue May 17, 2011 1:11 am |
Fast Eddie
 Re: Steering play
Hi everyone, I had a closer look at the play in my steering and actually it's only a very small amount of play. It's not the steering rack thankfully, but the column- just below the plastic cowl that holds the stalks and ignition switch. There is a section of the column that is shrouded by a plastic sheath and there is a join here where the column is at its widest point- this is where I have a small amount of play. I'm not sure how this join works but imagine it's a splined inteference type fit, although there is a thread visible. Anyway it didn't look like it could be tightened very easily. Should I be worried about this? Should I look to replace the column or get someone to put a blob of weld on it etc...?
Any suggestions...?
Ed
| Fri Jun 03, 2011 11:06 am |
malc jones
Joined: Wed Feb 13, 2008 9:58 pm Posts: 76 Location: Holmfirth, West Yorkshire
 Re: Steering play
Don't weld anything, particularly safety critical components, unless you are confident about it's "weldability", you could very easily end up with hazardous bruttle structures in the "Heat Affected Zone" immeadiately adjacent to the weld or even cracks and we all know what happens then!. By the way, when welding steel with poor weldability, a small tack weld will be more of a danger than a proper weld run because whilst it still obviously melts the metal it will cool far quicker than a larger weld and hence give a greater chance of hardened hazardous structures. Medium to higher carbon steels are the hazardous things to avoid unless you know what you are doing and can use appropriate welding proceedures. Things made of very low carbon mild steel are ok since there is not enough carbon to form hardened/ brittle structures but higher carbon steels such as high tensile bolts, suspension or steering parts are obviously far more critical and require appropriate welding proceedures. It is far better to leave these well alone. In my experience, not all garage welders know a geat deal about "weldability" so beware.
| Sun Aug 28, 2011 8:33 am |
Fast Eddie
 Re: Steering play
Thanks for the advice regarding welding. Fortunately the play i spoke of is not concerning me enough to prompt further work so i am going to leave it as it is. I will keep an eye on it to see if it gets worse but I suspect it's probably always been like it.
Ed
| Sun Sep 04, 2011 6:56 pm |
Fast Eddie
 Re: Steering play
Following on from this, I have now replaced some rear suspension components, namely cones, tie bars, lower arms, Hi Los and bushes. The handling is a fair bit better but still not right. I think I probably need the rossabitz steering lock kit but I still want to eliminate the small amount of play I have in the steering column. Has anyone any experience of removing the column, or replacing it..? Am I right in thinking it's a Triumph dolomite column...?
Any advice appreciated
Ed
| Wed Mar 14, 2012 12:41 pm |
